Hey guys,
Some of you may have met me before at events or cruises and seen my white HR31 GTS-X.
I've loved that car to bits, but I guess it was time for something new. I had my eye on this GT-T for some time, and finally it's mine!
It's a 2000 end of series 1. At the moment all it has is a kakimoto cat back exhaust, apexi pod filter, advan rims, and some sort of suspension that I suspect might be a factory upgrade option. (maybe someone can confirm, see pic below)
Anyway, see you all on a cruise or something ;)
https://www.sau.com.au/forums/topic/174157-3-steps-foward/
The 31 looked very neat, remember seeing it at a few meets, including a dyno-day.
This car looks nice as well. The suspension looks like a SK group buy deal. If it is, they are pretty damn good and handle very well.
Hope to see you around again.
What happened to the 31?
https://www.sau.com.au/forums/topic/174157-3-steps-foward/#findComment-3197159
Ah well, it's on ebay now: http://cgi.ebay.com.au/Nissan-import-HR31-...1QQcmdZViewItem
Time to move on.
nice champ :( that wud look good in the colour if it was a 4 door not a real fan of 2 dor r34s for some reason
says the man who had a similar painted 2door HR31 :)
https://www.sau.com.au/forums/topic/174157-3-steps-foward/#findComment-3207625
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
