Hi everyone,
Could someone please help me with my r32 skyline? Basically I've ran over a kerb, and I broke the castor rod and bent the control arm (front left). I've bought new one and tried to put it back in myself. however, it wont seem to go in... like it's not allign... I dunno if I've damaged the chasis also or maybe the strut aswell. Here's are some pics of it any comments would be appriciated thanks.
https://www.sau.com.au/forums/topic/174408-hit-a-kerb-need-help/
Did the same thing a year or so ago now and i know how much it hurts. Id suggest getting the car to a mechanic or at least a wheel/suspension repairer as there can be some "unseen" problems. Essentially when i did it the damage was only minor but it still needed to be checked on a chassis aligner, which as one of the checks to make sure the chassis rails are still aligned. If the accident was low speed then you should be ok.
Secondly i damaged my hub without knowing it and had to replace it. You will be suprised what a slow speed gutter collision will do!
Have you tried fitting the x-member end first, then connecting the hub?
That would be my advice as well. Then fit the castor rod to the LCA, then pull the hub forward and drop it onto the ball joint.
Check for other bent stuff too. The sway bar link is sitting at a funny angle, but that may be due to the lack of a castor rod to pull everything forward
yeah I tried that still wont do it, is it meant to be an easy fit or are you meant to force it in? also could the strut be fuekd?
I got the x member in and it went it pretty easily it just I cant get the hub in its been pushed back I think... so does this mean there's no chasis damage since I managed to get the castor rod and lower suspension arm in?
Edited by gtst7
There's no "strut".
Disconnect everything - hub, sway bar, castor rod - from the control arm.
The arm should be a tight fit into the x-member, and may need a spot of "persuasion" (if you get my drift). The hub will slop around because it's only held by the upper control arm. Once you have the arm attached and bolted to the x-member, the hub can be swung into position and connected to the ball joint. Now you can start thinking about connecting the castor rod and sway bar.
The castor rod forms the third side of the triangle to keep the wheel in position, so you may need to lever the hub assembly into position so the castor rod can be connected to the control arm. Connect the castor rod to the chassis first. Then move the control arm / hub to meet the castor rod.
Just studying the photos again. It looks like the link pin on the sway bar might be interfering with the positioning of the hub. Try tucking it back down away from the hub.
Also, is the car jacked up on both sides? Jacking up one side only loads the sway bar and can create difficulties getting stuff to line up properly.
My son did the exact same thing to his r32.
He broke the radius rod and bent the lower control arm back.
It bent the back of the crossmember backward from the LCA inner bush bolt outward.
After we straightened it and put it all back together with a new arm and radius rod he refused to pay for a wheel alignment and wore out a new set of tyres in 3 months.
When he finally got a wheel alignment he found the wheel was still pushed back 14mm.
We fitted another radius rod support bracket to fix it.
Even though the old one didn't look seriously bent it was.
Compare the LHS of your crossmember with the RHS side to see if it's bent.
Get a wheel alignment when your done.
yeah I jacked it up on both side... cant really see ne diff cept the strut seems a bit bent on the crash side... I mean can the strut actually be the solution?
By the strut do you mean the hub and knuckle upright assembly?
I don't think it bend in my son's car but it's hard to tell because it's not straight in the first place.
If it is bent it would cause all sorts of problems.
my car had same problem when i bought my R34 GTT
may be it was from japan... the caster rod was bented and left had side tire was wearing out sosososososo baddly....
i had to buy adjustable caster rod and changed them to adjust... my whole front bit was bented little bit... no one can tell its bented but if you see the nose part i see the bonnet and body doesnt lined properly... anyway... if your front bent due to that problem... adjustable caster rod will do. and wheel alighnment..
my tire is not wearing out anymore.. im happy now anyway
its all good unless i put NOS on....lol
good luck
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
