hey guys, im hitting the drag strip in a couple of weeks for the first time.
car-->98 gtt, 260rwkw @ 1.1bar, gt3240, single heavy duty clutch, front 225, rear 255/40/17 bridegestone re050.
turbo is set on relatively low boost because of standard engine internals. the car gets plenty of wheel spins both first and second gear on the street. so at what rpm should i launch the car? any advantages launching it on second gear to limit wheel spin?
should i ride the clutch or dump it?
what tyre pressure do I use? 30psi front, 22psi rear?
do i need to do a burn out? whats a good burn out technique to warm up street tyres?
as its a quite powerful car for a drag racing noob like me what other precautions or things that i should be aware of?
thanks for the help
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/174958-260rwkw-first-time-drag-techniques/
thanks for the help
do not launch in second...it will put too much pressure on ur car....wheel spin means less pressure on your car, and as long as its not too much wheel spin u will get off the line alot faster then no wheel spin.....u will more then likely bog down.
launch at 4 grand and see if you just sit on the spot, hopefully the car squeals and takes off....if u spin topo much bring it down a bit but i have noticed that 4 grand is good for me on street tyres. dont ride the clutch, but prob dont just drop it....but id say more drop it then ride it....
front normal tyre pressure and rears sound good.....definitely do a burnout....best way to get heat into the tyres....no burnout means u will be doing ur burnout off the line....
where abouts u from? where will u be going?
Little point in a burnout with street tyres, i've found heating them too much hinders.
I ran a 12.9/109mph with 220rwkw. 2.10 60ft, so not the best being my best laugh was 1.9 60ft.
You will get wheelspin, impossible to not, you just have to make clever use of the clutch and power at the same time to have the least amount of it (wheelspin).
I'd say starting off around 4000rpm and see what works, whats too savage and what isnt.
Either way its gonna be hard.
I also ran a 12.1 with over 300rwkw, wheelspin no matter what i did to 1/2 track hehe. So with 260 you might be able to pilot it to a mid 12 on street rubber.
I really should get something bigger than 225's for my rear :domokun:
thanks guys.
hmm..no burnout means u will be doing ur burnout off the line....while heating them too much hinders.. maybe something in between, a light burn out? how do you do a light burn out?
re 60ft time, is around 2 secs to be expected for a rwd car? i mean if more than 2.2 then i must be doing something wrong?
lol 225s are really too tiny for anything more than 200rwkw on tap :) A factory standard Porsche Boxster S gets 265/18 and only 165rwkw. Edited by BaysideBlue
yeah dont cook ur tyres but def some sort of burnout......light them up in 2nd and roll out....no braking....that should do it....
good 60ft for street tyres for a beginer is realistically 2.2....anything under that you got to be happy with.....i average a 2.1 on my 19" by 275....my best on them was 2.08....best i have done on street tyres is 2.025 but they were T1r's on stockies....
  • 1 month later...
sorry to hijack the thread a bit, but what if you have a clutch that doesn't allow for slip, im running roughly 200rwks on 225 toyo's. what would the best rpm to launch and how should i control the accelerator.
my fastest 60 ft so far is 2.23 but i know it can be faster, i just cant seem to get the traction off the line
any pointers would be much appreciated
cheers
do a decent burnout... use tyres with a good sidewall.. something like a 225 with a 50 sidewall so u can deflate them or a killer compound 255 tyre.. which you already have..
take off with no more than 6,000rpm and go easy on the clutch dont dump it..
i ran 1.9 60 footer on 205/55R15 $50 dollar tyres i got from newlands rd 2nd hand tyres
13.1 1/4 with 205kw
and a killer burnout..
Regardless... You need heat in ur tyres
thats interesting.
as my first time out, saw me doin a burnout the first 2 runs. then a rather experienced drag racer told me, "try not to do a burnout next time, as the street tyres perform worse hot". And as he said, I didnt do a burnout, and ran my PB time so far.
Edited by silverbulletR33
depends on tyres, some cars will launch better on cold rubber.
i dont see why your making all this effort to allow for crap tyres, when buying some decent ones will probly result in your best $ vs. gain on the track. why is everyone so dead set on getting big power when you cant even put it down properly?
a set of stockies is like $50 for 2 R33 rims? i know decent tyres arent cheap but for what you can gain, why not? have a spare set of rims/tyres for the track?
LTHLRB, damn good times for that power/tires. you've done well mate
No it's not a Skyline link, yes it's for a Supra, but again, most of it still applies (Bar how to directly adjust suspension stuff)
http://www.supraforums.com.au/forum/showthread.php?t=18639
And EUG, your bug gets me everytime! nearly everytime I go to wipe my monitor!
if you can select low boost for take off then do it.
try and slip the clutch and dont mash it off the line. it takes some practice to find the balace of slip and bogging down. but best thing is to get out htere and have a go :) and get a feel for how your car behaves.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
