SAU Caps & Beanies... just made a deal, any1 want one?
  • Replies 246
I'll take a beanie and a cap :D
I reckon for the beanie .... a set of skyline tail lights on the back of the beanie would be cool and maybe SAU on the front or something.
Make the ".com" bit small tho' so we don't look like nerds :cool:
dunno, atm its a tentative $20 (with about $3 goin to the club) but it could come down to about $12 even... all depends on the number we get.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
