SAU Caps & Beanies... just made a deal, any1 want one?
  • Replies 246
i created some designs
What do you guys think? I've tried to keep it fairly simple but also modern and in your face.
See the taillight thingo, and the number plate synergy there for those that miss the obvious at first :P
I think I like #4 the best myself and would work well on a black beanie with say a white for the emblem. Number #4 would look great on say a white tshirt too i think in the centre.
For the beanie we could maybe have just design #1 on the front bit and then a line of those red circles along the base stretching around (i think you can picture what i mean).
It depends on whether we want the SAU address on there or not. To me its a bit geeky, but could promote the club more. If people like my designs at all, I would probably work more on a nicer font for the www.skylinesaustralia.com text.
That is my bit..wow i actually used some of my skills on this site - amazing.
for the hats... i wouldnt mind having the word "skyline" above all embroided in silver, then sau below it etc
for the beanies - skylinesaustralia.com around the lower part, wif a smaller sau logo at the front a bit higher up
my 2c
also put me in for 1 each
Guest YZF-R1 Maniac
See the taillight thingo, and the number plate synergy there for those that miss the obvious at first :)
One of each would be coooooooooL
Why dont these pics work?????
Cheers:burnout:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
