SAU Caps & Beanies... just made a deal, any1 want one?
  • Replies 246
LOOKS GREAT THE WAY IT IS!
No gtr symbol please, it would look a bit "try-hard-ish"
Why not put the R33 skyline symbols as it is the middle model between the 32 and 34. :(
j/k
But serious about the GTR thing
Still one of each for me, thanks!
guys just a quick late notice question before the samples arrive... this is another alternate design we could have...
what do you guys reckon??
why not have to tail lights at the back... like a car ....... either gtr or whatever ... get orders for gtr or standard lights....then have the SAU symbol between them like a number plate... and on the front the skyline S emblem... then skyline australia on both sides at the bottom...
just a suggestion.
Originally posted by nismoR34
Perhaps a redesign of that using the S as part of SAU like the GTR symbol?
S
AU
I did one of them before, but people didn't warm to the idea, so it was relegated to a lil symbol on the back.
here's the one I did before:
I think I'll jus get them to do a sample run of this design:
... R33NismoGirl ... GTR lights and standard lights are the same...
poeple didn't want sumfin on both sides, although personally I'd like the lights at the back as well instead of the front. I'd rather have the skyline logo with SAU underneath it. I'll see if I can make a version of that as well just so I can explain it better.
nah I meant to try it with the badge S below but doesnt matter, i was just curious to see what it would look like with the badge-type S.
I wanted one about 6 pages ago...... Please just decide and say decision is final.
Make sure you get all the money up front before you place the order with the hat place or you'll have to pay.... James knows all about it :D
PS: I still want some too :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
