The gods have smiled upon us..........RX7 galore!!!!!
Even though I don't know the photographer personally, thanks all the same for these pants wetting photos. Only wished he had more.
You all need worship this guy for creating half of the cars found there
Who has more of these Rx7 pics from the 7/7/7 meet?
https://www.sau.com.au/forums/topic/176262-777/
damn right it is
must have been quite the noisy day for them
I met Dino at Fuji speedway when Poida and i went there for D1 last year.
Nice guy, well connected and very serious about his photography.
he has a Bayside blue R34 that he drove to the track that day by the way...
heres his site..
http://blog.gtroc.com/dino/
https://www.sau.com.au/forums/topic/176262-777/#findComment-3226375
yeah been following his site for a while now. Some really incredible photos he's taken.
Hes very talented. Knows just how to capture the moment and does pretty well for himself out of it.
on top of that he gets to road test some of the beasts too...lucky bastard! :thumbsup:
https://www.sau.com.au/forums/topic/176262-777/#findComment-3226981
just out of curiosity, is he 30ish, glasses, going bald in the front? (not trying to be insensitive or anything)
I found a photo of what looks to be his car with him driving on the highway.
https://www.sau.com.au/forums/topic/176262-777/#findComment-3227021
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
