  • Replies 244
Posted Images
Hey could you send me a PM if you have the front wheel inner guards please!!
Thankyou
Sorry no inner guards.....
Sorry if I missed it through the post, but I'm guessing headlights are gone?
sorry head lights are not for sale....
Hey Dude, I'm after the window weather seals that run along the top of the doors if you've still got them. RHS in particular.
Cheers,
Luke
Cheers,
Luke
Sorry mate the car never had those....
All parts are for sale, although I have sold most of the major parts including the engine, gear box and diff, don’t hesitate to ask about any parts not listed below.
Hi there,
Just wondering if you would have the blinker and horn contact assembly. This behind the steering wheel and has a connection for the horn.
Pablo
Hi there,
Pablo
PM sent....
hey mate i was wondering if that guy ended up taking the power window switches off your hands already or if you still have them. get back to me asap please on 0420383884 as i don't get on here much, cheers ashley
Mate a 93 modell r33 is a series one all day you have a series one just thought id let you know series two were produced frm 96 to 98. :nyaanyaa:
LOl, at least you know your r33's, but pity mine is an R32 like it says in the topic description.
Best read the post correctly before you start giving out advice.
Cheers,
Cheers,
thats funny - people have a habit of doing that on here
ANYWAYS - Coil packs? gone yet?
let me know
cheers
let me know
cheers
Sorry mate, but the coil packs are not for sale.
Cheers,
Edited by trezy85
pm sent regarding 'interior door seals'
but im really after the seal at the top of the car not attached to the door but seals the door window when wound up (both sides)
i think you've labelled it "outside window surround"
cheers
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
