  • Replies 244
Posted Images
Hey could you send me a PM if you have the front wheel inner guards please!!
Thankyou
Sorry no inner guards.....
Sorry if I missed it through the post, but I'm guessing headlights are gone?
sorry head lights are not for sale....
Hey Dude, I'm after the window weather seals that run along the top of the doors if you've still got them. RHS in particular.
Cheers,
Luke
Cheers,
Luke
Sorry mate the car never had those....
All parts are for sale, although I have sold most of the major parts including the engine, gear box and diff, don’t hesitate to ask about any parts not listed below.
Hi there,
Just wondering if you would have the blinker and horn contact assembly. This behind the steering wheel and has a connection for the horn.
Pablo
Hi there,
Pablo
PM sent....
hey mate i was wondering if that guy ended up taking the power window switches off your hands already or if you still have them. get back to me asap please on 0420383884 as i don't get on here much, cheers ashley
Mate a 93 modell r33 is a series one all day you have a series one just thought id let you know series two were produced frm 96 to 98. :nyaanyaa:
LOl, at least you know your r33's, but pity mine is an R32 like it says in the topic description.
Best read the post correctly before you start giving out advice.
Cheers,
Cheers,
thats funny - people have a habit of doing that on here
ANYWAYS - Coil packs? gone yet?
let me know
cheers
let me know
cheers
Sorry mate, but the coil packs are not for sale.
Cheers,
Edited by trezy85
pm sent regarding 'interior door seals'
but im really after the seal at the top of the car not attached to the door but seals the door window when wound up (both sides)
i think you've labelled it "outside window surround"
cheers
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
