Wow.. i thought it was really rare to still have a boost restrictor still in place. I heard they have a yellow band around the hose where the restrictor is.. did yours have this and is it obvious? Where was the hose?
I dont think you will have any problems. Ive got a 32gtr and i couldnt find this boost restrictor so I assume its gone and car runs perfectly fine. To my understanding, the car was designed to run the full boost anyways and it was just one of the ways to reduce the power to 206kw for japan. saying this.. im not a trusted source of info so maybe someone else can confirm
I had a search here and basically everything i said was wrong.
Im assuming now that my restrictor is still in there somewhere. I might look for it tonight.
So yeh, running more boost means your giving the turbos a tougher time. You dont want your turbos to shit themselves thought as the debris from a rooted exhaust wheel could damage your engine.
from memory there are two hoses coming off the "boost soleiniod"
about an inch down from the soleiniod on one of the hoses was a yellow band of paint (0.5cm thick),
i squeezed it and could feel something solid was in there,
took me 5mins and i am no good with cars
It dose seem to make a VERY loud rush of air sound at boost.
dont know how normal that is
I will take it to cruz this week and get some more advice
that is if no one knows what i mean about the sound
Edited by Y2K
yep thats the hose to pull the olive out of and always will give you a dead accurate 14.5 psi, the turbos are fine on that boost if they arnt in to bad condition, just make sure if you have a computer to get it tuned
If i only have the stock computer will i have problems with the engine running lean
yeh... but now with 14.5 psi, things might be different.
maybe the fuel pump isn't up to the task?
I was mainly refering to the thread owners.
but if you have gone from 10 - 14.5psi, it's be worth re-checking surely.
it's not like it's cheap to build these rb26's... even to stock level...
$50 is cheap insurance and piece of mind.
if I ever get an RB26 powered car, it will defeinitely have a compression check, leak down test, all new fluids, new plugs, and a dyno run.
a little outlay up front but good cheap (in the grand scheme of things) insurance.
OK dyno is booked for AUG 1st (he will do all combinations of equip eg with out boost restricter, put boost restricter back in and combos with anything else getting put in) so i will post results incase people are interested
It was also mentioned to me that changing the cam sprockets
would be a good AND gentle mod to perform
What say ye SAU
nah man it's just the GTRs i think
my R32 GTSt and GTS4 don't
R33's done either, they do have a solanoid you can put a switch on though and run higher boost at lower rpms(33s have a controller to run 7psi at below 4000 i think it is, then switch to 10psi or whatever it is standard)
you could also look out for a bleed tap, there is an article in the DIY section i think about a ball valve type bleed valve, which is meant to be an excellent controller :) and a lot of people have thrown away(well sold) there electronic ones and replaced it with the tap, it only costs round $22 as well :D
the main problem you will face now is keeping your license intact...enjoy! Standard turbs will last fine on 12psi (except maybe extended track use)
niggah wot?
i spent 2 years thrashing my standard turbo 32 GT-R at just over 15psi (including 4 track days) and it was still going strong, lol
I removed my boost restrictor almost 2 yrs ago, runs 14-15psi (up from11) and no dramas. power jumped from 198-230rwkw with just addition of apexi panel filter and removal of restrictor.
So no aftermarket computer ? When you run it on a dyno were the fuel mixtures within range?
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
