PM sent regarding the seat.
EDIT: I want that drivers seat, assuming it didn't get damaged in the accident, has a blue 'trim', and isn't worn out on the rhs bolster. Have cash here and waiting, and am prepared to drive down to Melbourne ASAP, whenever suits you. Cheers.
  • Replies 138
will also trade for pparts of intrest,
twin plate clutch to suit early 32 gtr
550cc or higher injection
18" wheels i dont want no fake te37s n shit like that
aftermarket cams
coilover for 32 gtr just let me no what you maybe intrested in other thing
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
