sigh
got defected for
- horn not working
- rear brake light not in centre of window
- wrong tyre load rating for wheels
Would anyone have a set of rims/tyres for r32 in road worthy condition?
Going to have a chat with my dealer about this and was hoping for a backup.
Wouldnt mind buying a set if anyone has them for sale
Thanks
Patrick
https://www.sau.com.au/forums/topic/176652-anyone-have-rimstyres-for-rw/
Well well well.....wasn't out mate was it?
He's SUCH a FU(KING bastard, I mean with those defectable items you're looking at a top 8 spot on the worlds most dangerous terrorist short list. You're right up there with Osama! I feel a hell of a lot safer knowing you're not on the roads anymore......I mean really :P
Bit of a laugh, even the guys at the EPA reckon he's a wanker.
haha yes it was the famous cop from Knox
He was polite and informative though, although he was firm in believing the r32 was classified as a high powered vehicle.
Was driving under speed limit and all of sudden there is a undercover behind me flashing to pull over haha
Happened on intersection of stud and burwood hwy
If anyone has spare set of tyres please contact me asap
Cheers
Cheers
Yep he was VERY polite the first time he pulled me over, very similar situation just round the corner on the way home from the Mrs place.
Second time he was an asshole from the word go and he hadn't even looked at the car yet :P
He told me vicroads doesnt know and that you should contact police.
He took the unlaiden value of 1250kg, which was displayed on his computer screen along with my estimate of 158kw stock.
Which made it 126kw/tonne
He said that because its only 1kw above the law, they are lenient. But if i get in accident he will fine me.
Once you get confirmation from Vicroads please forward me the email as Id like to keep a copy in my car.
your welcome to borrow my stock set. but i suspect you cbf driving to my joint :P
If i get desperate i will, cause i cant find anyone else.
Went to import wreckers, mechanics etc asking for bloody wheels but no one seems to have a set. Where are all the r32 rims?! this is crazy talk
Might talk to my tyre shop and see if they have some steelies which will fit on my car lol
Cheers
hey guys just wondering if anyone here would be kind to let me borrow a set for road worthy??? iv got tread on mine most places that i took the car to to get RWC said the rears are to low around the inside edges.
would throw in a slab for the helping party. will only need it for one day. will not abuse the tyres and if its damaged i will take full responsability for it and will pay for it.
im in Rowville and it would be awsome if someone could help me out.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
