Ok, so last week i purchased some new Gf7 18" wheels from tempe tyres. I had some speclation to wether they would actually fit an r33 as the stock brakes are quite large, but the tempe staff assured me that they would fit and they would even send some spacers just 'incase.' The wheels rocked up at my house after a couple of days, when i searched through the boxes i found no allen key specific to the the size of the new nuts that came with the tyres.. with a little improvisation i managed to get the nuts fully tightened and the wheels on, all looked pretty sex.
A little later i took the car out for a test run with the new wheels. It was evident after just 5 mins of driving that something was not right, i was getting really annoying vibrations and shuddrs on deseleration and some pretty nasty sounds. I took the wheels of when i got home to investigate and found metal filings on the base of the new rims... (oh shit). i made sure i had correctly fitted the tyres and went around the block to try and find out what exactly the problem was... once again shudders. I spoke to a friend who works at beurepaires and he told me a few things 1. Spacers are absoloute shit and 2. they are illegal. The spacers i was provided with did not fit like i was told. The quality was so bad actually that just after going around the block my rear right was near falling off. The spacers weere actually knocking the bolts out and creating a gap between the rim and the hub, this was also causing grinding (i.e. the metal filings) so i immediately took the wheels off and got the stockies back on. I spoke to a another mate who has bolted-on spacers and he too is finding similar problems and is getting rid of the wheels.
Tempe told me to call back tomorrow as they pretty much cbf'd sorting the problem out. Hopefuly i will be able to get a refund or an exchange for something that fits. Just making my problem known to anyone who has or is considering getting spacers so that their new wheels will fit... its definatley not worth it. lol. + if you go throught the pits they will slam you for it. If you are buying from tempe be weary not to get rims that require spacers, eventually you will just be sending them back :) . pce.
https://www.sau.com.au/forums/topic/177056-caution-buying-new-wheels/
firstly, did the wheels arrive with the tyres fitted and balanced? tempe isnt exactly recognised for quality rims and tyres. an imbalance could be enough to upset things to the point of loosening the nuts.
secondly, u say u had to 'improvise' with tightening the studs. that to me says, u did a half assed job instead of going out and buying the correct size socket fitting for 5 bucks. ur lucky you didnt round off the nuts half way onto the stud, then you would be in all sorts of shit. if u were using an incorrect fitting, then you probably never had enough torque on the nuts to get them tight enough.
thirdly, the nuts on the spacers also have to be on tight as buggery. any play, and like u have noted, the rim will gradually work its way off.
fourth, spacers aren't the problem. they can cause imbalances yes - but plenty of people run them, myself included, and so long as u exercise a bit of caution they are perfectly fine to live with. for example, when i take a wheel off, i put it back on, drive for a few minutes, get out, and retighten. 9/10 times they need a bit more tightening after the initial tighten.
fifth, tempe may have said they fit, but the fact they sent you spacers leads me to believe that they knew they wouldnt, or that they advised you that its 'possible' they wouldnt. 5 mins of research on this site before you bought your rims would have told you the exact offset necessary.
sixth, dont buy new from tempe. buy second hand jap rims from a forum or an importer. better quality, better looking, more value, bulk respect.
Quick tip, make sure when you speak to Tempe ask for the guys name so you can speak to the same person every time...will save you alot of trouble....
I've found them hard to deal with over the phone as I also had to sort out a problem with them too (sent rims but one was the wrong colour :))
wat size (mm) are your spacers and how long have u been using them for. Also was kind of nuts are u using and how many?
important lesson learnt. if you buy rims with the correct offset you will not need spacers. ;)
The most important lesson is that if you buy rims from Tempe, don't expect them to have rims in the correct offset or be balanced.
No matter what wheel you buy, it is recommended to retighten your nuts after about 20 kms, and this must be done correctly with the proper tools, i mean, your wheels are the only thing holding the car onto the road mate. when using loose spacers you need to retighen frequently as they will and do compress slightly over time and driving.
that said they should have told you that any spacer or adaptor not welded onto the hub and engineered is illegal and defectable.
Also make sure you have the centre hub rings fitted, these are different to spacers and should have been provided free with any set sold.
Sounds like you need a lower offest wheel...
Edited by T187
get the right offset firstly when getting new rims..
For your sedan it should be anywhere between 30-45 lol..
Go to their shop and get it fitted, if you still insist of buyin rims from tempe..
Theres plenty of rims on sau for sale section!! Should have checked that out first..
looks like you learnt the hard way tho..
Edit: i hope you havnt put chromies on your car.. :ninja:
Edited by siddr20
Edit: i hope you havnt put chromies on your car.. :D
haha no chromies.. not a fan. yeah i probably should have,, but the rims i saw on tempe caught my eye first and i had to have them.
spacers do not cause problems unless they are poor quality or incorrectly fitted - I have run them for years on my street/track (drift) car, both slip on and bolt on type, I even went over the pits with them and no probs
you get what you pay for - no such thing as a bargain when you are buying new, your wheels (and tyres) will make a big difference to handling and affect performance.
If you cant afford decent new wheels - you cant afford new wheels.
there is a very, very good chance that if you didnt have a correct key to tighten your 'allen key' nuts, they werent tightened properly, which can cause problems even without spacers
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
