Hi
After several years of good service my chinese, stainless low mount has cracked in half.
so im wondering if anyone has seen a low mounted gt3540 IW on a 6Boost or Extreme turbo manifold.
i need to order one sooner then later as my wife is without a car at the moment, so any ideas would be appreciated.
thanks
Darren
i know they both make them and that there products are very well made, however i also know that there manifolds dont mount the turbo in the standard position its rotated 90 degrees i think, so im wondering on if the gt35 will still fit with the internal gate etc side ways instead of the standard up and down configuration?
i dont want to fork out $1100 on manifold then find out it wont fit.
Yer it will fit lowmounted. I had an externally gated GT30 all low mounted and that fat fine.
The IW is longer, but not as wide, so i see no reason that a manifold made to suit couldnt fit the turbo as the dimensions are very similar to what i had.
Although, you'd best chat to the guys, im sure if you give them some rough dimensions they will work it out.
Its a common car, and equally common turbo config
But i've seen TA45's low mounted, so its definately possible, just need a new dump/lines possibly depending on how its made
whats wrong with using the std manifold? Not that i wouldnt suggest going for a better exhaust manifold, but if the power isnt enormous and its not going to restrict your setup in anyway then why not use the std piece? Or maybe get the std one power ported and use that. Just another option if your not too certain on the a/m ones with turbo placement and whatnot.
its on a built 25 with forged rods, pistons, cams etc running around 300 - 320kws at 22 psi.
running r33 auto with full built box and 3k high stall from MV Auto.
just looking at the low mount pics and they start getting a bit messy.
open the bonnet and theres pipes going everywhere.
so from a police point of view would high mounting the gt3582-iw be any better?
certainly looks a lot cleaner / stock.
hahahaha sort of....
I was going to suggest that. The manifolds aren't produced any more afaik and i only ever saw them to suit ex gate setups. Putting a gasket and a plate over the ex gate outlet will work fine. I have done that before when running a highflow on a high mount stainless manifold.
That said, i can't confirm whether the IW housing will fit in the space available
i was going to get a low mount manifold made by 6boost, for my gt3540 IW that i had,
he said it costs abit more than a high mount, and its not worth wild. As it would be tight as F#$k and the amount of heat being produced in a tight area. Even if you have to pull the turbo out at some stage would be a pain in the arse.
Direct quote from Kyle (6boost)
Keep in mind that in standard form, the factory manifold is only about 4" thick, and the turbo flange points straight at the block. The only manifolds that you can get that will fit in the standard location are those poxy stainless jobs that are absolutely horrid. I can't build you anything in the stock position, and can't see why you'd bother to, as there is no room to fit any type of decent collector. My low mount would be something similar to the one pictured in my thread here:http://www.calaisturbo.com.au/showthread.php?t=107446
I highly recommend you don't go low mount, they are very bad for transfering heat into the engine bay and make working on the engine a pain in the ass. However if you must have a low mount, the price is $1200 inc, and comes with studs, nuts, turbo gasket and lifetime warranty against cracking, defect and failure.
My vote for the HKS low cast manifold , cast/provision for ext gate/split pulsed/can take T3 or T4 flange . I also think that GT3540R (GT3582R) is a lot of turbo for the power . The difference in effort and money to go even a little over 300Kw seems to be vast and not always worth the outlay .
Mafia here went to a lot of effort to drag 300Kw out of his mechanically std R33 RB25DET and did so with a GT3076R possibly with the Garrett GT30 .63 A/R integral gate exhaust housing , or was it the .82 A/R ?
I've not been there myself but I think if you had the head ported and fitted Poncams the .82 A/R exhaust housing may give reasonable response depending on what you think is ok .
Cheers .
Just remember that UAS Extrusion hone the factory manifold to produce 25% - 35% more flow for $500.
Factory manifolds can be had almost for free.
I'd definately look into that..
So a search for "Extrusion" and "UAS" I'm sure you'll find plenty of info. There is a thread where they flow test etc.
Edited by The Mafia
Umm... its actually the opposite mate.
A low mount is better for under bonnet temps than a high mount.
^ x2
Do a search on one of my threads on high vs low mounts.
Low mount is better in everyway except fitment of the turbo. My race car is currently changing from high to low, better centre of gravity, can sit further back in the engine bay (dump pipe is lower and allows closer placement to firewall).
Youll find sydneykid`s replies to the aforementioned thread the best. He converted me.
cheers guys
ive ordered a high mount Extreme Turbo Manifold to suit the internal gate gt3582r-iw,
and im contemplating ordering a greddy plenum to go with it, due to cross over pipe issues.
any thoughts?
no...greddy you lose some downlow....but achieve more midrange to topend. More so topend. But its neat and tidy and looks the part. Depends on how finicky you are with your setup. Other aftermarket plenums that maintain the std runners help keep the low to mid without sacraficing too much top end.
having a 3k high stall convertor takes care of any low down loss, and the added flow ability with the new exhaust manifold should also help the power curve.
i was thinking the greddy plenum looks nice and neat without being overkill.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
