Here is a Radar Detector that is no longer needed as I bought a couple of years ago when i was a hoon but with new laws wont even bother to use it and have no use for it still works fine comes with all attachments and wiring necessary for it to work ........just dont get caught with it.......... sell for 300
Edited by wrxxy
https://www.sau.com.au/forums/topic/177148-fsradar-detector/
  • 4 weeks later...
how well do they work mate? i.e do they tell you like 200m away there is a radar ahead? or only when you're pretty much on it? and dont you have to sit them on the dash or something? making them real obvious?
Cheers mate
On your windscreen up high with suction caps and have hard wired or into cigarette lighter plug.
For radar guns it works from far coz radar gun have strong signal, but for speed cameras it only works from few hundred meters enough time to slow down coz speed camera very weak radar signal.
In any case when it beeps or starts going troppo slam the anchors on as they (the police) need to have a bit of time to lock you in.
Edited by wrxxy
hmm.. Ive accumulated 12 demerit points.. im on probation for a year. I wonder If this thing would be a smart buy? considering if i screw up once, i loose my licence for a year. what do u think?
Slow down and less burn outs? :D
Cheers mate
I think you will find that every state use's laser guns now, laser guns do not put out a signal untill they pull the trigger (unlike radar which is always putting out a detecable signal) so unless you are near another car that they are targeting you will not have any warning.
if you download the 3rd image with the brochure you will see that it detects radars & lasers
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
