hit the bank then rolled? still looks driveable to me you big girl :teehee:
yep, managed to drive up the bank on the exit of a nice simple open corner, and barrell-rolled off the top... it probably was still driveable, but the driver had had enough!
Cheers G T R, i think i saw you at lakeside on monday. Does your 32 have the black rays rims with the red writing around the center?
Zennon: Yeah its still rb20 powah at the momment. In my first session on the sprint i ran a best of 1:20, next session i ran a best of 1:16 my next and last session was a best of 1:12.
On the national track i only had 1 session and my best was 1:37.
I could make a few excuses but i achieved what i set out to which was to
a) go as fast/hard as i can without destorying the car or oiling up the track and making a dick of myself on my first day out there
b) not come last :wacko:
Hopefully ill be out at the nissan day to help out but my work hours are changing and i wont have tuesdays free anymore :)
More RB20s out there the better. Though i read Gts30t is going to the darkside, if nothing else the user name change hints at something fishy. So think you shoudl stick with the RB20, your car will be much quicker with the money spent elsewhere on the car!
I post this a lot, but is pretty good indicator of how the RB20 can do the job better then anyone credits:
Comparison is both against RB25 NEO engines, both with GCG Hi-Flows, Bass Junky with same tuner and dyno and Poncams. Now tell me that the RB20 with the right diff ratio and turbo cant match bigger displacement RBs to the point where they are a huge hindrance.
LOL, stick with the RB20! Sooner or later you will ditch it, but shouldnt be on the must do list unitl lots of other things have been done :D
A hks 2530 makes about 210 rwkw. Need to get some injectors and have it retuned though, the guys at the last track day told me it was pinging a fair bit.
What times have u run around there?
I have only ever done the sprint track - and haven't been there in ages.. best i've had is mid 62's :D
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
