its certainly fun to drive! Mine was used for street/drift in Japan before it came over here. Had 9/7kg springs when I first got it! But in that vid it had the 7s (390lb) in the front and 325lb rears. The rear end still hates any hint of a bump! I've now moved the 325lb/in springs to the front and waiting on the 225lb rears to arrive. Should calm it down alot. But I'm more than slightly sceptical about the rear Tein Drift-Spec shocks as well... also have some rear radius/traction arms to fit, and after those changes I might try some pineapples if it still needs more traction. It will get there eventually. It hasn't even had an alignment yet!
Here's another update with my big little engine project. I spent last weekend installing cams, rocker covers and assembling the intake manifold and throttle body setup. The external oil feed for the head is now connected too.
The picture shows a standard RB26 timing belt on the engine which is too short. Ive sourced a suitable length belt from an audi 80 series that solves that problem. Twin tensioners are used to allow the cams to be positioned properly at 0 degree's. My high octane sump extension is being welded on this week and the pair of GTRS's should arrive fairly soon too with any luck, so not long till its finished now.
That is a mega mint R32 Ben, i sincerely hope mine looks half as tough
should have kept your weds then you homo. I still have mine. :D :D and they are the super duper 17X9 +18 ones. :)
I will give you 60k for it. Thats the going rate for a pedigree R32 these days isnt it? Yeh, the Weds are lighter then the homo TE37s i have got now....stupid me. I may have to grab back my 17x9 Weds and accept that i will only get to run 235s and not the 255s i hoped to run in the 9.5" TE37s.
I knew you'd pick that Harry. LOL
To be honest, I just can't keep it flat, it needs a little lift to get some transfer onto the front, otherwise big understeer = hello grass maybe wall. lol
I'd imagine though, if I did grow some man-balls, I'd be even faster than you than I already am around there :D lol (just playin mate :D)
Edited by Marlin
Nice looking engina :)
Flame captured on film..... might be due for a new cat convertor you think? :D
lovin the flame pic!
yet to get a pic of mine doing that... when it shoots a fireball at night it lights up the whole cabin... yes I have the maturity of a 5 year old :D
good looking car ben. i miss all the damage thoe. its just to straight.
oh and dont show any cage builders that pic because your A pillar bar is all wrong. :D i jokes with you.
I'd imagine though, if I did grow some man-balls, I'd be even faster than you than I already am around there :D lol (just playin mate :))
I was kinda asking for that... Just enjoy it while it lasts mate! hehe
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
