  • Replies 66
Originally posted by SHUTO-BOY
if u put it on, ill affect the aerodynamics of your car i guess, stick lots of small paper strips all over your car with and without the wing on,  and see the turbulence (i guess nobody has the time haha)
hahah after exam I love to try that on paul's GT wing... lol
The ruling is, it's legal if the wing is within the bodylines of the car, and it has no sharp edges. The sharp edges is where the disagreement come, as the cops say the GT wings are sharp, and the two pit places I've taken them too said there not:D
mmmm we just got a shipment of top secret carbon fibre wings :O)
i think there around $1200.00 retail. they look bulk nicer than the aluminium gt-wings.
That blue 350z with that wing looks really good on that car.
Pauls car on the other hand just looks gay :shake: :(
You mean like this?
Which pit is this :D ??
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
