  • Replies 843
Posted Images
Don't worry mate, perfect excuse to build a stronger and quicker RB25 show em how its done :laugh:
HURRY THE F*CK UP AND GET IT SORTED SO YOU CAN COME BACK TO THE DRAG STRIP TO SHOW US HOW TO DRIVE!
:laugh:
<Nice shopping list btw....droools...> :laugh:
Awww man I was hoping for some more theatrics when it blew :thumbsup:
Can't wait to hear and see this thing with the new set up though.....
Just make sure it has a mean arse exhaust note to let everyone know how mean that engine under the bonnet is :rolleyes:
