  • Replies 843
Posted Images
I was genuinely disappointed with the result - should have run another pass or 12 on the bottle huh?!?!
It wasn't running that well to be honest.... Sounded nearly as shithouse as an SR20DET.
Gate is love. :thumbsup:
I reckon 10 passes in it, maybe 1 off the bottle would have been required.
haha, ye i know the SR20 put-put sound all to well :worship:
it wasn't the nitrous at fault of course.
Go back to a stock turbo and punch 300hp worth of gas into it for the 9. :thumbsup:
Get some NUTS! :worship:
Hindsight is a precious thing.... I'd love to just bottle fhe fark out of it for a pass or two. As it stands I can't see anyone else approaching the 11.662 stock turbo mark in a hurry.
/looks_at_rev_and_winks
I'd like to see this 'stock' turbo of yours...:thumbsup:
You'll have to pull it off the car it's currently fitted to. The buyer was a bit dissapointed that it was ceramic as he knew the car and thought he was getting a bargain - HAHA!!!
Eug - I've had years to consider this build :woot:
yes should be good!! i cant wait to get my car out there again!! im afraid i will get kicked out and need tech inspection. extra 100kw at wheels and a ppg 5 speed. on a 11.3pb >_<
You reckon? :(
u could just get it tech'd u know dave :(
yep he certainly did. decided to go with the single shot for now, if i find the 125 shot isnt big enough i'll go direct port, but i'll see how i go for starters. price wise he was gooood >_<
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
