  • Replies 843
Posted Images
Cant Remember if its been covered and cbf reading through 8 pages.
Pump Fuel or Race fuel? and will it still be gassed up.
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :P
Regards Andrew
And now that you've sold the C4 are you going back to manual? I remember reading somthing but cant think where :rofl:
Regards Andrew
In order:
- Race fuel
- Yes
- Didn't sell the box from this car. I still have the C6 in it.
Intake update: I can get a couple more of these (plenum/TB) at $1400 if anyone is keen for one. Just send me a PM and I'll sort it out. They use the std throttle cable and TPS as well.
Adrian
Looking very nice man - how quick are you aiming to go with this???? Going by your nack, I'm not going to be surprised if I hear very near single digit numbers - if not...
Thanks mate. I don't know if this setup will have a 9-sec pass in it to be honest but it'd be nice to do. Not sure if the GT35 has it in it but there's only one way to find out :thumbsup:
Hello Mrs Courier!
These look bloody awesome. The throttle body is a work of art too - can't wait to bolt it up and have some fun!
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :thumbsup: )
Good luck,
Ryan
I have one of these on my set up it helps i think, especially if you are running a high mount turbo. Just make sure that you make your own gasket to go between the top and bottom sections, i had problems with mine comming out the back (it has to be at least 5mm thick, it will also stop a little of the heat transfer :banana: )
Good luck,
Ryan
Thanks for the tip. What did you make it from?
