  • Replies 843
Posted Images
i agree that a good quality kit is much less of a headache to fit, but some cars are shit to work on regardless. i replaced a set of low mounts on a 33 gtr last week. used some manifolds with a balance pipe on top so had to fabricate water feeds, also fabricated oil feeds as the hard pipes are a mongrel. after 2 days of f@%KING AROUND I WENT HOME AND TOLD MY WIFE I DIDNT WANT TO DO THIS ANYMORE. im closing the shop at the end of december. from know on i am only working on nissans with chevs in them. you can all jam your 300s, gtrs, gtirs etc. funny that nissan build the best sports cars but also the worst to work on. i now agree with he mentality of other shops to charge like wounded bulls to work on these heaps of sh$t. charging fairly never got me anyware. the day of the modified street car is dead as most shops cant be f@cked and people wont pay the money the job is worth, unless your from sydney where it seems you can charge anything and people pay. plus cops are sending everybody to EPA testing. looks like dedicated track cars are the go and people will be doing there own work. thats my rant and before you ask, yes i have had a few beers.
thats why i work for a race team. as soon as the welder or lathe or mill gets used its $140/hr...... but we only do race cars. and the pay is shit :P people dont seem to understand that a "custom" job isnt like a "bolt on" kit.. ive f**ked around for 2 days now doing the diff and gearbox coolers for the ute that we are running in the 12hr.. just takes ages..
end rant .. bring out your car adrian i live 10 mins from the wsid..
Had Leigh from Extreme Turbo Manifolds make me up a custom catch can today. The guy is an artist, what can I say?
These are the push-in fittings that tufrx3 turned up for me. They were a tight fit (a good thing) and I'm happy with the finish.
expecting it to breathe heavy or something?
There is nearly 10 litres of oil in the engine. Should something go wrong, I'd prefer that the catch-can will be able to deal with a large-ish breathe before dumping it elsewhere (under the tyres for example). It's for safety's sake. What's wrong with that? For a smart guy you sure come out with some weird ones.
Jas, first skids on Monday.
Cheers.
It just looks like a nicely welded, shiny box in those pics but I got to see every step from design to finished product and it's all incredible.
Better welding than my car deserves, that's for certain!
How's this for good lookin'? ;)
tongue in cheek :P
well its good to finally see its done and ready to race ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
