  • Replies 843
Posted Images
Started plumbing up the surge tank, new rail, feed and return lines and other stuff today. It's not finished and the cable ties are only to hold things in place while we measured to get the right length of braid etc and won't be there when it's all done. All done with proper bulkheads in the boot and teflon braid so as to sto as much fuel smell as possible.
Big thanks to Steve from Steve's Speed Shop and BezerkR32 for their assistance.
looking good mate :P
any reason you havent used a larger return line? and did you use the very top (vertical) fitting for the surge tank feed or return to tank or return from engine?
Im asking this cause ive yet to do my setup (the tank has been mounted for months in the car though lol) and everyone does it slightly different
Hi Mate - the return from the engine is -8AN which I think will be plenty large enough. It's the top-most feed in the side of the tank. The feed to the surge tank (just below the return from the engine) and overflow from the tank back to the main fuel tank (very top fitting) is -6AN.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
