Hey
Not sure if i should post here or in the skyline section, but i just went for a drive and while rolling at about 90kmh in 5th, take my foot off the throttle, put the clutch in, ease on the brake then all of a sudden it stalls, all lights on the dash come up, no power steering, it has been doing the same thing since about a couple of weeks ago just randomly, normally the revs just drop right down and then come straight back up to idle but this time it completly stalled, the car runs fine when coming to a complete stop everywere else, it just seems to do it at the same peice of road just before my house (no, im not saying the road is causing it lol). any ideas on what could be causing the problem? its not a vaccum leak cause if it was it would stall while its idling, im running the stock bov ,im stumped as to what it could be, O2 sensor of afm maybe?
I could plug in my PFC and do a sensor SW check and get the reading of all the sensors? would this tell me anything?
Any help would be much appreciated!
Cheers
https://www.sau.com.au/forums/topic/177768-random-stalling/
sounds similar to my car
would hestitate at any revs and any time
stalls, and wont start for a few turns of the key, then drives normally
im replacing my afm, if i watch the graph vs afm signal, im getting vertical drops in the signal randomly
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3245205
what if it is the road?.. It could be haunted..
Do not take this as a joke.. :D .
Some say that there are certain places on the Earths surface that have a magnetic anomaly...
(A word I have always wanted to use)
This causes cars to stop..or..electrical faults to occur. :D
It can also cause drivers to fall asleep or faint at that point..causing major problems...even accidents.
These spots can change or can always occur constantly at one point. :laughing-smiley-014:
Heard of the Devils Triangle?
This can explain..all of the faults we experience in our cars.. and we can blame these anomolys(twice in one night..yippi):D
I am not in anyway in charge of myself at this point..so whatever I have said should not be held against me.
Written and authorised by M J..Mc Dougan..Canberra..LMCT 1234....conditions may apply...... :nyaanyaa:
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3245816
Hey
Cheers
Get a second hand AFM....
If that does not fix it......try changing your TPS...then sensors as a last resort..unless you can get them cheap..
You will need to change your tps.....in the short future anyway..due to age of car.
It can also be an electrical fault..or computer is playing up..some can get that way...If you can find one to plug in..second hand and see if this fixes it.
Could also be pressure drop in fuel...check your pressure lately?Or injectors get sticky....and clogged..try some fuel additive......EDITED:(This is an add on).
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3245820
So you guys reckon afm? im thinking that aswell, the car does hesitate and surge somtimes but nothing to major, just seems weird that all of a sudden it has got a problem, might take it into nissan and see what they think :D
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3245928
So you guys reckon afm? im thinking that aswell, the car does hesitate and surge somtimes but nothing to major, just seems weird that all of a sudden it has got a problem, might take it into nissan and see what they think :thumbsup:
They know jack shit...trust me.....
get a second hand one...try it and see if it fixes your problem
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3247546
Yea i think i will just do that, or buy a cheap 2nd hand one, i dont want to buy a brand new one as i need to get my z32 afm in the future anyway, it happen again today by the way, ive checked all the pipe for splits and lose hose clamps but everything is fine, ive checked all the intake pipe setup and bov return line aswell and all is fine, so im leaning towards it being the afm, would a faulty afm cause it to only stall randomly ,if the afm was fauly wouldnt the car run like crap??
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3247573
Ive checked all the intercooler piping, intake pipe and bov plumback line, vacuum hoses and tightened all the hose clamps ,everything looks fine to me, im running the stock ecu at the moment, but if i have to i could plug in the PFC and see what the airflow voltages are while im driving.
Is there anyway i can test the afm to see if it is faulty? would a dry solder/joint cause the problems im having, i thought that a broken joint/solder in the afm would cause the car to run completly crap and hardly drive at all?
cheers for all the help, would be great if i could get some more opinions :)
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3253942
  • 3 weeks later...
Mine does this as well, stalls when coming to a stop from 3rd/4th/5th. When it dies, power steering goes away, brakes go hard, all the dash lights go on etc. Mine is 100% stock so it isnt a bov issue. I need to get this fixed because i cant use the brakes properly when coming to a stop since they harden.
Would a dirty afm cause this sort of stall? Im pretty sure the battery might need replacing too, because when i bought the car it had been sitting garaged for quite some time (long enough for the battery to die).
What else can i check? Searching the forum also suggested aac lines but im not confident enough to check it out myself just yet. The car will have to get a roadworthy in a week or 2 anyway so i can atleast tell the guy about what is happening. It only started doing it this last week; it was fine before that and passed a rwc last month.
I havent really driven it since it is unregistered. (only to and from vic roads)
Also, i was told just before i boguht it, it may need injector cleaning; would carbon build-up cause something like this?
Im just trying to narrow it down.
edit: stalled about 3 times to vic roads, maybe twice or 3 times on the way home
r33 96 gtst s2
Edited by delljit
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3285455
It starts first time always; although it does make a sort of high pitch noise for a second or 2 when i start it sometimes after its been sitting for a day or so.
Guess ill just have to get it checked out; i wouldve liked to solve it by myself though.
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3288614
  • 1 month later...
Bit of an update
Just bought a 2nd hand recondition AFM, changed it over today and no difference at all :( so im a bit stumped, i can actually make the car stall on purpose, for instance i can be in 5th gear at about 90kmh,give it a bit of throttle then just before it starts boosting, put the clutch in and put the brakes on slighty (it dosent stall without the brake not being on) and the revs will just drop and car will stall, it likes it just cant catch its idle.
Anymore ideas on what it could be? the car runs great apart from this problem, not sure what to check next, 02 sensor? idle valves? TPS???
Might plug my PFC in on the weekend and check the TPS values etc etc
Any more help would be awsome, cheers guys.
https://www.sau.com.au/forums/topic/177768-random-stalling/#findComment-3362730
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
