  • Replies 175
confirmation to get 3 for me. thx :D
No problem at all.
Cheers.
I have just sent a PM to everybody that i can see has said they want one. Time to pay up!!!!
If you didnt get a PM let me know.
Its not too late if you still want one. (Again, let me know and ill PM you the details) Im trying to get a cut off date for This Thursday but it may need to be opened another week while people organise their payments etc etc.
I will let you know when the order is placed, and when the delivery of the units to me is expected.
Thanks guys.
Brad
so i was about to transfer the funds and realised i live in rockingham how much posting do u want if its doable to post it to me , wasnt sure if its to much trouble ill come pick it up of u some time but postage would be less in fuel lol .
matt :yes:
matt :yes:
I can arrange postage for you. I use Foxline couriers and it will be $6 postage per order to get to Rockingham. e.g 1 unit will cost $33 + $6 postage. 2 units will cost $66 + 6 postage. etc
Any problems let me know. When i have received them ill put up a post, then PM with your day time delivery address.
Cheers
Brad
Cheers
Brad
great, as well as sending and recieving orders i have to also send out a trillion fire extinguishers LOL :action-smiley-069:
Hey dude.. I was wondering how much would postage be to Sydney?
And how soon would I get them after Ive paid?
Only reason I ask is bcoz ive placed an order for a fireexthingusher from firstaidsales.com.au and havent heard or recieved anything from them.
And I need the fire extinguisher before the 23rd Aug.
:D
:D
Id be happy to organise it for you, but Freight would be no less than $20 which i think would make it too expensive. Are you sure there is no where else in Sydney it can be purchased from?
great, as well as sending and recieving orders i have to also send out a trillion fire extinguishers LOL :D
That is because you are Brad's Prank Monkey!
You will learn to love the job...
Dance Prank Monkey Dance!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
