hi
could someone please steer me in the the right direction for paper work and what ever else is required for importing a race only car, i have purchased a car in japan and need to import it , it will not be being road registered ever(circuit only car.
thanks russell
https://www.sau.com.au/forums/topic/177894-import-question/
car is being built for time attack in japan and the u.s.a
and these events are not cams sanctioned as far as i know?
cheers russell
so what do you mean?? you want to import it to australia, to build it here, to then use it back in Japan and the USA?
https://www.sau.com.au/forums/topic/177894-import-question/#findComment-3250224
even in that case, you will still need to apply for a race/rally approval through DOTARS.
I hope you like paying $$ to shipping companies!!
the link razor$harp gave you above should have all the info you need to be able to do it...
in SOME instances, you may get away with only having level 2 cams licence, but level 3 is what is normally requested.
let us know if you have any further questions.
Cheers,
Beau
edit: another consideration.... you are meant to provide with your application proof that you have competed in events here before, along with evidence of events you plan to enter over say the following 12 month period.... so if you are planning to only use it in Japan, and USA, DOTARS may not like that.
Edited by insanity
https://www.sau.com.au/forums/topic/177894-import-question/#findComment-3251530
I'm sure Russ has the competition experience required, you need to provide its plans for future competition as well. And the person who applies for approval will need a PC or NC license - but you can sell it to someone else once it is here.
Pretty sure you will need an import approval each time it is imported back again - sounds like a lot of trouble to me.
Cheaper to build 3 shells to the same specs and leave them there at 2-3k per import (RORO) and even more in a container
https://www.sau.com.au/forums/topic/177894-import-question/#findComment-3252408
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
