Let me know too - mine's worn, and like you, I find it Waaaaaaay too big: kinda like:'avast there mates! Hard to port!'.... like steering the fairstar, without the whole breaking down and sinking issues...
I was thinking N15 Pulsar SSS wheel: same design, but smaller diameter from memory.
Even thuo some of the nissan wheels look the same, the airbag module/plugs are different and some have different black boxes built into the wheel behind the airbag module.
I had a pair of R33 GTR steering wheels. They turned out one was from a series 2 GTR and the other was from a series 3 GTR.
I have seen a few stagea's in Japan with r34 GTR wheels, but not sure if they have the airbag plug in.
Could maybe use a r34 GT or S15 wheel?
Best chance is to try and get something from the same year as your car
I have been looking for a Momo factory option wheel for a while, but most for sale are for other model cars.
My car is in at the moment getting gearbox converted to manual, so I do not want to keep the tripronic steering wheel. but the buttons on the wheel could come on handy for NOS :laugh:
a very long time ago.. i was looking at a photo worklog from someone in japan doing a swap with a s15 steering wheel...
the work log seemed to indicate it was a straight swap....
wouldnt have a clue where it was i was reading from tho.. sorry
i couldnt find a s15 wheel.... cheap enough to warrant the swap...
Does the 33 or 34 gtst wheel swap straight in with airbag fittings? the stagea wheel is too bloody big for track work
Bah... Duncan's stealing all my ideas! Next he'll be putting a lift kit and mags originally designed for a Nissan Patrol on it!
'sif I'd really do that. :(
  • 1 month later...
hahahah brilliant! :laughing-smiley-014:
Yeah I'd go for the S15 wheel, they are much nicer,
just make sure you disconnect the positive terminal and discharge it before removing it, or it could hurt you, and definitely don't sit on a bucket with one in it
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
