Hey SAU
i have recently purchased an R34 gt-t and am wondering, like the r32, can you fit the R34 GTR front bar and R34 Bonnet,
while still using the standard head lights and guards ??
I know on my r32 this was not a problem...
My car came with a carbon bonnet and front lip to look like A gtr which i have removed...
I have sourced a GTR front bar but still looking for a bonnet. dont think it will be easy to find.
Anyone done this before ? and do you have any pics ?
Tours.
https://www.sau.com.au/forums/topic/178057-r34-gtr-bar-bonnet-fit-r34-gts-t/
To make a GTR front fit on a GTT you have to change bonnet inc. gtr hindges, front bar and guards but i think the head lights are ok not sure about them.
Its better to get a gtr style bar/bonnet for the gtt from a body kit place.
RTK
RTK
Front bar is ok, but the Bonnet is the main one im after, as the aftermarket bonnets are all defectable, i just took off a carbon fibre gtr bonnet.
Hey SAU
Tours.
yes, but the bar will look shite (same as a genuine GTR bar looks shite on R32 GTST) as it will bows in for the narrower front guards.
just wondering...do u have to fit GTR guards??? or just for the looks...any idea where to get hindges...thanks
I think you might need the guards to match up the front bar.
I have found all parts, bonnet, bar, and guards on yahoo japan...
Have a look on there for the hinges.
then you'll need rear guards to match up the front guards :(
no you DO NOT NEED gtr guards in order to have gtr bonnet! do a search. this got to be one of the most asked questions re r34 gtts!
I have an R34 GTT With a genuine R34 GTR front bar and it fits like a dream. not sure on the bonnet tho. looks hot too...
Excellent think i might start collecting some bits,
I already found front bar for $450, and bonnet i will have to import from japan.
Can you PM me a pic of your bar fitted to the GT-T.
Mark.
how much does the gtr bonnet usually cost? i assume its genuine and not fibreglass or carbon?
The GTR bonnet is aluminium for Vpec & Non Vspec. Vpec 2 is carbon but it is painted with air duct on the turbo side. Prices vary for 2nd hand. A friend of mine just converted his and the weight difference is that the GTT is so much heavier.
From my experience using a GTR Top Secret Dry Carbon bonnet, the handling is so much better and the car weight transfer feels more neutral. Plus the cooling benefit under the bonnet due to the hot air venting out from the scoop.
Edited by driftmeister
If you buy a GTR bonnet, you will need to change the bonnet hinges, lock panel and lock assembly to the GTR items. This will then leave a gap where the top mole of the front bar should be.
If you then buy a r34 GTR front bar, it will fit but the edges will not align properly due to the wider fenders of the GTR unless you do some work on it.
I'm going the east bears direction and should hopefully get it within a month or so. Plastic and no mods required.
I have a lip that if i use the stock bar, i can just put the lip in, and it brings the stock bar up to meet the GTR bonnet.
Unlike the R32 i dont think you can cut the GT-T Bonnet to look like a GTR as the GTR bonnet rises up and the hump is bigger to meet the front bar lip between the lights...
For prices on the bonnet contact forum sponsor slidewize, and search yahoo japan, there is a nunmber of them on there.
I have a carbon/fiberglass bonnet, but i have taken it off for defect reasons aswell, its a clearly obvious defect from a distance...
Tours.
driftmeister.. did your friend convert his gtt bonnet to gtr? i really don't want to go carbon bonnet as i don't want to get defect for it.
He is using the whole front section of the GTR = Bonnet, fenders & front bar. You may need more parts other than the hinges and hoodlock. The front bar actually sit on a panel (not sure what part number) between the headlight which the GTT doesn't have. Plus once you install the fender, there is a small gap when u fit the small section like an inch lower than the GTT body. See the pics attached then u will understand.
i have these fill panels ready to go here in aus see http://www.uras.com.au/syohin/skyline.html#r34
Remmeber no matter what anyone says GTR bumper on GTT looks real shit as it has to bow in to compensate for narrower gaurds. I would seriuosly consider a aftermarket GTT bar of some description.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
