I didnt think you could use mild steel for cooler piping as it would rust. When you say rust proof it do you mean rustproofing both the inside and out? If so, how do you rust proof the inside??
powder coating the insides is possible, just difficult to get 100% coverage
https://www.sau.com.au/forums/topic/178073-cheap-piping/#findComment-3254164
Was going to make a new thread but Im curious if anyone would want to fabricate me some cooler piping, I was going to buy a Blitz LM intercooler for my r34 as it directs piping back under the cooler and into stock pipes but my other option is a titeass front mount and pipes.
Can anyone help? Sorry bout the highjack but why waste space..
Oh ill pay too :D in sydney
https://www.sau.com.au/forums/topic/178073-cheap-piping/#findComment-3255363
  • 1 month later...
in my opinion stanless is the go easy to work with look great can be shiny can be mashined look or you can paint it and every place has it mandrel is good cause you can buy it at any decent fabricator,zaughst joint
i have doen all of mine in stainless always and when you are putting 20 psi thru it you can clam it down as hard as you want and the hoses wont blow off it would be the same price as ali
https://www.sau.com.au/forums/topic/178073-cheap-piping/#findComment-3325707
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
