I just bought a gts-4 for my younger brother's first car. After driving it for a week or so I'm reluctant to hand the keys over with the car in its current state. From what I've read the stock actuator on the r32 is 10psi and the stock actuator on the r33 is 5psi with the boost solenoid taking it to 7psi. I have a turbo and actuator from an r33 and was planning on swaping the actuators to achieve 5psi until he has some more time on the roads under his belt. Is there anything I'm missing or need to know?
On a side note the cheap looking boost gauge in the car seems to read around 13psi. The car has a separated dump, 3" exhaust and an upgraded SMIC which might account for a slight increase in boost but I wouldn't have thought that much. Maybe the mods coupled with a dodgy gauge is the reason for the higher reading.
https://www.sau.com.au/forums/topic/178150-r32-gts-4-turbo-downgrade/
depending on what state you are in it may not even be legal for him to drive it (if he is on his p's).
putting the lower actuator on will lower the boost, however it won't take it down to 5psi. exhaust and intake mods will bump it up a bit.
From my experience, using the stock r33 actuator alone, even with mods, the boost was around 6 psi. With the solenoid, it went up to around 8.5/9.
It is straight swap and a great way to make the car a bit safer while he's learning. It won't make it too slow either if that makes sense. It'll still be faster than most things out there.
Yeah not a bad idea there mate, should work too.
You may not get exactly the same boost level as you would in a 33, however it will give you less boost than a 32 actuator, which is basically the point of why youd be doing it anyway.
you can also take the R33 actuator and elongate the hole by filing it so there is less preload on the spring:)
or if you want to disconnect the rod from the wastegate flap leaving the waste gate open all the time.
an R32 with 5psi is still a very fast car for an inexperienced driver. I can guarantee I would have crashed one if it was my first car.
Hey thats a good idea. A lot less work than changing the actuators (providing the rod is easy to access) and if its tooo slow then I'll chuck the r33 actuator on. I dont necessarily want to take away all the boost but I guess I'll see how it drives.
Wind the ign timing back 10 degrees. Thatll take power out :laughing-smiley-014:
Probs the easiest and you dont need to take a hell of a lot (i was kidding with -10) to decrease the power considerably. Just watch the engine temperature. Pig to drive tho off boost.
Controlling boost is the best option tho but at least you know you can do something else.
You could make up a restrictor plate for the exhaust, maybe just punch a 2" hole in the restrictor plate and place it somewhere between two joins in the exhaust.
It will still look and sound like a tuff exhuast but the restriction will bring down power considerably + its cheap and easy to reverse.
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
