Can anyone explain how the fuel door works on the 350 GT (2003 model). Sometimes mine (rarely) flicks open when the remote is used and other times it remains locked and I have to get to the lock throught the boot to release it.
Also has anyone had troubles with the driver's power window and central locking?
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/
Body Control Module- it operates 90% of the car - if something is out of kilter then things stop working. inputs are resistive on these so if the input (IE switch ) stuffs up - no worky.
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3261387
Can you let me know more about the BCM - how to find out if it is faulty, do you replace it or can it be fixed or reprogrammed, is it a common fault, where is it? Thanks
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3261510
  • 6 months later...
Hey guys,
This is going to sound REALLY odd. But I had exactly the same thing, I'd lock my doors and my fuel cap door would pop out. My fix: I switched on the mirrors tucking in when the car is locked. It no longer pops.
Freaky, eh?
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3638212
My fuel door must be faulty as it will not lock when the car is locked.
There's a little solenoid which drives a plastic lock that engages with a catch in the fuel door to lock it. Locks when the rest of the car is locked. Look just inside the door and on the left you'll see the mechanism.
Apparently it is quite common for the solenoid to die - the one in mine was dead. From what I've heard fairly easy to replace if you can source a replacement solenoid.
Those who were having trouble with the door popping out - could be due the catch that engages with the lock on the fuel door being mis-aligned. Check if the catch on the door is bent or twisted in any way.
Chris - the winding up of windows when the car is locked - are you saying this can be programmed by the dealer on any V35? Or is it dependent on a sensor being there as well?
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3645601
depends - have seen dealer fitted units that do it. unsure if it can be done via consult3. I'm working on this one anyway as I want to do a snazzy alarm on one and close everything with a push of a button.
any one got fast for a V36 yet?
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3646018
Mine can...... bummer....
As I said in my post - busted solenoid actuator...
This is what you need, first part on the list since it looks like you have a Coupe (I think...):
http://www.trademotion.com/partlocator/ind...amp;catalogid=1
Riverside Infiniti was one of the better places to source V35 parts though I gather the guy who was really helpful has left so maybe find another dealership. They all seem to use the same parts catalog system so shouldn't be too hard to locate this part again. In any case make sure you check that it is the correct part before ordering!
Or just source it thru Nissan...
Edited by Ant
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3668742
well, kptechnologies (http://www.kptechnologies.com) make a unit that has been made specifically for the G35 to do just this
go to their website, go to products, then select "wondow roll-up"
they sell it for USD$50
not sure if it can be integrated into our car due to wiring differences between G35 and V35 but i'll throw it out there for those interested..
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3681607
KP Technologies also do a unit which dips the side mirror(s) when you put it into reverse - tempted to get that and the window roll up unit... Though I should just build one myself, wouldn't be hard to do with a small micro...
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3685166
my mirrors dip already when i put it into reverse, i think its combined in the reversing pack with the camera :P
although interstingly, when chris had my camera disconnected for a while, the mirror dipping still worked.. maybe there is a separate control module or its already got the provision for it as standard on the V35?
this was never an option for the G35, thus why KPtechnologies has made that module for them..
https://www.sau.com.au/forums/topic/178397-v35-fuel-door/#findComment-3685319
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
