older style HKS t04 turbo still in great condition .50 comp housing and large rear .96 rear wheel. suits 2.0ltr+ 500hp turbo. minimal shaft play side to side (like play that new turbos have, basically no play when oil is in), absolutely no in and out play,no fin damage, no oil leaks etc etc.
contact via pm
$800
pics added
Edited by ilum4eva
https://www.sau.com.au/forums/topic/178805-hks-t04-turbo/
are you sure that's an HKS turbo? all i see is garrett in the picture?
cheers,
marcus :down:
EDIT: I see it now on the top of the exhaust housing near the flange, sorry.. free bump :thanks:
Edited by aphid
https://www.sau.com.au/forums/topic/178805-hks-t04-turbo/#findComment-3268806
Interested, what did u have this on ? Rb25 ? whats the spooling up like? slow/fast? is a modifyed manifold needed or will it bolt straight on to my Rb25det?Im guessing it has an external w/g cheers
Edited by madaz R33
https://www.sau.com.au/forums/topic/178805-hks-t04-turbo/#findComment-3268915
I have to add this. open the second last pic. stare at the turbine wheel for a sec or two, then look to part of the carpet in the pic. now it will look like the turbine wheel moves. unless I had one too many pills with breakfast....
https://www.sau.com.au/forums/topic/178805-hks-t04-turbo/#findComment-3279751
hahahahaa yes!!! it does too!!!
BTW: if you look carefully you can see the HKS on the rear housing right where that bolt is.
https://www.sau.com.au/forums/topic/178805-hks-t04-turbo/#findComment-3279769
Would really be best if you answer the fitting question in the thread, would save you some time.
As other ppl have asked is this a direct bolt on for an rb25?
https://www.sau.com.au/forums/topic/178805-hks-t04-turbo/#findComment-3280194
