Spotted this NSX at the Glen, don't think I could give up this much for a car though...
i saw that aswel looked nice..i rarely see any. I did see one about month or so ago...duno what was wrong with it but sounded like crap and was about to break down.
On the way back from the show and Shine spotted a Greeny colored brand new Aston Martin V8 Vantage Roaster. OMG THE NOISE IT MADE FARRRKKKK
should have heard the noise nick made after eating duck once......boy did it stink
Spotted red delta integrale again on waverley road this morning, plates HIFI 20 - this time with L plates...
cool! I've always wanted an Intergrale... I used to learn to drive in my old mans Fulvia Sport... 1.3L of fury! also drove his Alfa GTC quite a bit... double clutching FTW hehe... modern cars are so easy in comparison
neither were remotely as quick as an Intergrale tho!
Geez Ash - you're slipping!
Jarrod wins :D
Will sort out a nice prize for ya.
It's one hell of a scrape though - on a Scud! I don't know how you could even do it so badly, let alone in a $700,000 car!
Mind you, someone in Sydney has done a real number on the front left on the QP. Evil curbs are everywhere.
Thats a shocking scrape!
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
