Ok folks heres the deal...... I'm a lazy bastard and can't be farked, and want a pro to do it!
I want someone out there that can detail my car inside and out, including Cut and Poilsh, and possibly a engine steam clean! I want someone that knows what their doing, like a pro......
So does anyone want some cash work or does anyone know of a mate or a mates mate that is a Car Detailer like a Car Groomer or something and can give me a killa cash price!
Any help would be jolly good.
Cheers
Darren
https://www.sau.com.au/forums/topic/179218-car-detailing/
Give Prestige Car Care a buzz, guys name is Tony and his number is 0413 459 087. He used to work for Lexus but left cos he knew he was great @his job & could make plenty more cash doing this type a work privately. Prices start from $40 onwards, tell him the Georgiou's sent ya.
https://www.sau.com.au/forums/topic/179218-car-detailing/#findComment-3266436
Get a sponge, bucket, some soapy water, and a total disregard for the environment and wash the damn car yourself you lazy bastard.
I use RO water and an Enjo car cleaning mitten to do my spot cleans, Otherwise I go to BP and clean it there for 4 dolla.
https://www.sau.com.au/forums/topic/179218-car-detailing/#findComment-3266536
i did it for 2 yrs as a job still have all the gear . but i hate doing it now even my own car hardly gets a full detail anymore . my mrs got fed up and paid some bloke to do both our cars .
slugged over 200 bucks and did a shit job that will teach me lol
https://www.sau.com.au/forums/topic/179218-car-detailing/#findComment-3270112
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
