depends on cams and head work auto or manual what rear housing?
but to make over 400kw at the wheels i would use a gt42r did one on a friends car and in comes on full boost at 4500rpm and has made and easy an 600hp on 98 fuel
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3269515
What's your intended purpose for the car? ie strip / circuit / just a quick street car
Will the RB26 be in a manual or auto car equipped car?
TO4z with a 0.84 will do 400rwkw at a lower boost level than a 3540 with a 0.84 however I'd guess would reach full boost approx 600-800rpm later. My TO4z reaches full boost around 4600-4800 rpm in thrid.
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3269531
i get 20psi in 4th gear just before 4000rpm
garrett t04z with 0.84 and 6-boost manifold
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3271453
thats actually better then what i expected...what cams you have? I bet those 6boost manifolds relli do work huh?...Im thinking of getting the larger 1.x a/r for outright power. Its a rb25 with cams and headwork....Will the turbo drop off boost during gear changes? How much power varation between the .8x and 1.x a/r?
cheers
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3299436
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
