use the hi octane exchange sump. way better than a puny 800ml extra. ive seen bearings spin on gtrs wityh the extension. simply not enough oil.
the sump i made holds around 8.5 litres to the high mark on the stick. no surge at all as yat.
you can't use both. but for me unless you have a high volume oil pump (like tomei, trust etc) I would use the baffles.
simply because to fit the extension your sump needs to be cut in half and I have seen some welded on extensions that were done pretty poorly. and it's very important that the pick-up is sitting at the right depth inside the sump. also they hang quite low, it shouldn't be a problem, but if for instance you spun off the track backawards over a ripple strip (happend to me!) it would be in danger of getting collected. plus the extra capacity adds a lot of $$ to your oil change if you are using oil like motul chrono (which you should be).
so I reckon unless you really need extra capacity, just use the tomei baffles.
...also they hang quite low, it shouldn't be a problem, but if for instance you spun off the track backawards over a ripple strip (happend to me!) it would be in danger of getting collected.....
That's what worries me about the extensions.
well...i've had both on my race car and have seen some minor surge using the tomei style baffles - never had any sign of trouble with the trust extended sump.
but keep in mind this is on excellent tyres with great traction, right on the limit - I don't think most cars would see any difference.
re clearance I've run the extended sump on plenty of tracks including some offs and not hit it......but thats not to say it could never happen - the trust sump definately hangs lower than the subframe
Thanks for that, I do intend to run the car at the track so good to hear from someone who has tried both in those conditions
I'd say that has more to do with the build and not overfilling than not enough in an extended sump.
well I'm convinced. both dave and duncan I know have thought about this a lot. so I'd go with their idea. especially if you are using a nismo oil pump (not nissan N1, but actual nismo pump) as they flow a fair bit more oil than a stock pump at any given pressure.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
