Hey dude chasing sunvisors and the std front indicators the ones in the bumper???
also after some interior pieces ie stereo surround, left hand air vent surround, climate control surround??? let me know what u got my pig needs some dressing up
price to perth 6061
cheers dude
froggah
got the standard indicators thats all $100plus post
Edited by drftnfrysi
  • Replies 80
Hey mate...
looking for the drivers side blinker (the one next to headlights)
also the sunvisor clips... the push in push out thingys... you know what I mean??
Cheers,
Beau
still got exhaust? how much? also after tailshaft? Wat diff u got ? price? am in Sydney
i got the exaust still looking for 300
dont have a tailshaft
i got a 5bolt halfshaft tight viscos lsd 150
all prices are not postage included and u organise ur own postage
do u have the front ceiling reading lights? with all plastic surround etc if so how much and psotage to sydney.
cheers
alex
yeah i got them make an offer and well go from there
?Have you got 1 damaged headlight (hence listing only 3)? i'm after a smashed headlight (read cheap to expirement on) with semi-intact internals and semi-intact plastic backing. doesn't matter if the glass is destroyed just as long as the projectors aren't totally fubar and the plastic backing that bolts into the car isn't in 4 pieces.
Cheers.
Cheers.
no sorry i thew it out
have you got LHR quarter panel
if yes is it still on the car or has it been removed? if removed where is it cut off at
pics?
a pole ran into mine
i still got it its on the car
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
