Hey all
Just had a long weekend in Tokyo and while I was there, i stumbled upon the Nissan Gallery. Took a few pics of all the GTRs and previous model skylines that were on display. Have a look if you like.
http://www.skylinesaustralia.com/forums/in...m=1943&st=0
Dave
https://www.sau.com.au/forums/topic/180287-nissan-gallery-tokyo/
These cars are taken from the Nissan collection which used to be located at the Zama warehouse.
If i recall correctly, they do keep a unit of each production model in their collection. so the mileage are usually very low.
I have sat in that R34 before...its as new as u can imagine =)
I wonder how many KMs on those cars
Imagine driving a 'straight out of the box' R32 or R33 GTR. No aging of parts to wear them down and no rattles too.
Glad you all are enjoying some of the pics. Was great to see so many fine examples of the various GTRs in one place.
It's hard to describe exactly where the main gallery is but there is a smaller one, which I found first, right at the Ginza 4 Chrome intersection and they have a handout of how to get to the main gallery.
The small one is located off the Ginza subway station (Gate 9??) on the Ginza or Hibiya lines from memory.
Dave
  • 2 months later...
It would be pretty cool thats for sure. It was unfortunate that in the past we didnt get the R32/33/34/35 aus delivered. But It will be great when the new skyline makes it out here- not that I can afford one.
I'll drag this thread up with the following link:
http://www.twinturbo.net/net/viewmsg.aspx?...;msg_id=2079707
56k beware.
:D
Seems he's a 300zx fan..precious little detail on the 32, but the 390, the mid4 and the LM 33 are interesting...Noddies fire truck FTW though
It's a post on the worlds largest 300zx forum, TTnet, so no surprise about the content, but what a treasure trove.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
