Hay guys i wonder if u could pin point me to the problem earlier today i dismantled the hosing feeding the BOV and put a bottle cap in der to make it whistle newaiz no probs all of a sudden cumn off da freeway on bulla rd exit my car turns off brake lock up steering no power n felt like crisis could u help me as to what this mite b 95 r33 gts-t
https://www.sau.com.au/forums/topic/180412-engine-playing/
Not sure what you are talking about, typing in English would help alot, and not sure what you are asking help for.
A more detailed explanation of what you did, what happened, and if the car is currently working, would help. Please use English and leave the sms jibberish for the mobile, you don't have a character limit to you post/replies, on the net.
https://www.sau.com.au/forums/topic/180412-engine-playing/#findComment-3282953
hahahaha, it sounds liek you've blocked the BOV return line to get the fluttering turbo sound :S
that will make your car stall man, on stock BOV, it'll put air through the AFM backwards and cause it to stall
That's why you steering and brakes went all heavy, because your engine was idling so low or died because of it
I say, put another bottle cap in, drain your radiator, put clean water in and a bit of coffee
put some sugar in if you want, rev to 9000rpm and you'll have a nice espresso maker for any ricers that might be driving at the time...
Or take the bottle cap out, return it to stock and drive it properly, with the bov working
https://www.sau.com.au/forums/topic/180412-engine-playing/#findComment-3283946
I always thought.....if the thing works.....don't f%^k with it.
If you are not sure what parts do what and how.....leave them alone.
he obviously knows what that part does..
I mean he used a coke bottle cap.
isn't this obvious that this man is a highly qualified engine modifying guy?
https://www.sau.com.au/forums/topic/180412-engine-playing/#findComment-3285717
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
