Hi GUys,
I nearly sold my Turbo 4 (old 944 porsche) after getting aload of this audio. Apparently it's leaked from holden's ad agency and is from the new VE ute.
http://www.therobertson.com/mp3/SSV%20SING...REV%20CLOSE.mp3
There's more at here too http://www.therobertson.com/mp3/ if you wanna listen.
I reckonit sounds better than my 4 - waht do you think
A little birdie told me they are trying to get sometyhing going virally via http://evolutionendshere.com ..
Check it out - could be cool
Mike
https://www.sau.com.au/forums/topic/180796-v8-sounds-vs-turbo/
  • Replies 41
why do i see this thread being closed soon?
anyway, i reakon the falcons have always sounded better than the commodores. they always have. especially in stock form. if you look at every comparison done in the past 15 years and they all say the ford v8 sounds much beefier. the holdens didn't start to sound good till the gen3, but i still like henry's donk. similar power from a smaller motor.
Hey all you turbo drivers, what sounds better? The turbo's you all have or something you chose not to buy?
er 1 turbo please
edit: IBTL :)
Edited by joeyjoejoejuniorshabadoo
O.o engine noise? V8's hands down.. Even a crap 8 with a nice set of extractors and a decent carby will sound mean, when we're talking a tuned 8 they sound heaps better... The whoosh turbo cars have is cool but it is pretty queer when it's louder than your under-bonnet engine noise and almost louder than your exhaust (which is generally pretty droney and boring anyway) ._.
That's my opinion anyway.. I reckon my GTR sounds pretty girly.. Also that car thing up the top sounded crap, sounded alright till like 3k rpm then it sounded like a 4 lol could just be the headphones though
Edited by r32 gts-turbo
i just listened to it. sounded crap. my rb sounds much much better than that.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
