2007 - The Year Of The Broken Skyline
84 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I have a feeling that 2007 should be called the year of the broken Skyline.
Mine's been broken for nearly 3 months... Is yours broken, or has it been off the road this year waiting to be fixed (for any period of time)? And why?
https://www.sau.com.au/forums/topic/181217-2007-the-year-of-the-broken-skyline/
  • Replies 73
Yeah... but only cause I wanted to make it a little less stock.... :(
Now it keeps biting me in the a55..... buuuuuuut... this weekend as long as no more turbos sieze it will be back :rofl:
Mine's been off the road since late February :rofl:
CAS died while driving fairly hard, overheated the hell out of it, needed a new turbo and decided to do everything in one hit. Work on it has taken forever having it done through a friend and now have totally lost patience and taken it to a workshop to have the rest of it installed. Should be pretty nice when I do eventually get it back though...
techincally no...
oh wait...
yes :rofl:
damaged front bar... with a long ass repair time...
f**k
last year was worse for me though, but this year, about 80% of my friends that drive have had major car problems... 2 being written off, and one being burnt to a crisp... the rest are things like, getting keyed, broken difs, blown turbos, warped brakes etc etc etc...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
