hey guys, dont you just hate it when you are driving through a car park and there is a smart ass that just decides to walk in front of ya and doesnt get out of ya way. as soon as i pass em i wanna give him/her a lil punnishment hehe. so i am asking are you able to have some type of purge without having to use nitrous??
https://www.sau.com.au/forums/topic/181338-purge/
Get caught with your nitrous kit attached on the road here in WA and recieve a fine and a red sticker.
I can't see a purge kit scaring many people. Have you seen one activate it's definately not the 4th of july. Try a set of truck air horns or a starter pistol plumbed into a solenoid if you want to be a weirdo.
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295675
Get a CO2 Purge Kit on the front of your intercooler, that way you *might* scare parking lot wallabies and it will also serve a purpose (condenses the air going into the intercooler).
Or if you really want to scare them plow right through them!
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295715
Bee*r Rev Limiter + Lotsa revs = smart ass needing new underwear.
what he said... FTMFW
had this guy go to us at the lights "your back wheels are going ot fall off, im like na thats the major negative camber and he disagreed and thought we knew what he was on about" he got highest stage bee*R with his window open.
he well shat.
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295834
One of these suckers will do the trick
http://www.youtube.com/watch?v=FONe--EjCpc
HAHAHAHAHA that is f***n funny, yeah id say go with an air horn. I bought one from motorquipe in carousel for 25 bucks. . . . Just shake, aim and press the button. . . .Very loud and cheap to buy, and fun to scare people haha
Edited by Daniel R32
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295965
kekeke when i had bee*r i did that to some lady walkin on the road blocking the way when i got a chance to go pass her i revved it up and loaded past her and then bang bang bang she shat herself
mmm good times good times :P
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3296014
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
