and here's the proof! and yes the pics still aren't any good, but give me a break I was using a 5 year old canon compact camera and it was freezing farkin cold!
Good job though with the point and shoot... with a 1 sec max shutter speed yeah?
But Iiiiiiiiii dunno Richard... they still look fairly close to the ground :)
I'm not sure if you can class one of these as a tripod:
lol, how did you know what I have!?! it's like you looked into my backpack and stole my studio quality camera and "tri-pod".
and yeah, it was a powerfully lame camera. good for a compact but in the grand scheme of things pretty rubbish. especially since the next day I dropped it and permanently fvkced the sensor.
seriously though, those pics were like 4 feet off the ground. :)
You are right I forgot beer.... I am thinking the next project should be a Integra shopping list car as it was an integra that inspired me to do that chop. I will either get a pic of an integra or get a better side on pic of my skyline and build a new shopping list car.
I remembered to add cheese twice because you can never have enough cheese
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
