that is old skool
been around for like 5 years.
why would you buy it when you can get a screw and stick it in there yourself?
the little hole is there for a reason.
it helps to open and shut the bov faster.
if it's blocked, the car feels a little more jerky on the transition point from boost to vacuum.
as in when you back off from the accelerator in a gradual fashion (like when you drive on the street)
I meant in the sense if you dont have a stock BOV and want to go back to one which is able to hold slightly more boost..
BUT, that being said, where do you stick the screw?
  • Replies 80
see in that guys pics of the bottom of the bov..
there is the large circle in th emiddle (the piston that is effectively the bov.. it opens and shuts) and then to the side there is a smaller circle.
that is the screw he has put in there.
a small wood screw does the trick.
if that bov wasn't modifed, it would look like the bov on the right in this pic.
http://herpetology.com/dsm/bov10e.jpg
Got it! Sharpkunt.
Thanks
not having a bov will not break the back wheel of your turbo.
if anything, it's the front wheel that "could" be damaged.
i think it depends on the boost your running n stuff but saying it wont damage your turbo is a bit of an understatement, especially the ceramic/ plastic wheeled ones
This was a good read this thread, the right amount of BS and info.
LMAO @ chicks getting wet.
but just to say, that my cars does still back fire and spits flames on stock. i was considering getting a aftermarket plumb back system to suit my r32 gtst. just for wank factor and new noise, but then blocking off the BOV is good too
as for damage being done to your turbo without having a BOV, yes that is correct, not to the wheels...but to the bearings in the turbo.
Edited by Oblivion
no bov/tight bov = flutter right?
flutter is the caused by the air that was SUPPOSED to be released from the bov.
the air that went in from the air filter, through the FRONT wheel of the turbo, through the intercooler, to the throttle, that was supposed to come out of the bov when the throttle shut, has no where to goexcept back the way it came.
therefore, through the intercooler, through the FRONT wheel of the turbo, past the AFM... etc.
so, the air pressure that reversion (flutter) puts on the turbo is only one the front wheel.
Skylines turbo's have ceramic EXHAUST wheels and steel front (COMPRESSOR) wheels.
Series 2 r33 gtst and R34 gtt's have a ceramic exhaust wheel and a plastic (some form of plastic anyway) compressor wheel.
the wheels are connected by the one shaft.
You know when you buy a second hand turbo and people always say "it's got minimal shaft play" etc..
well there are 2 ways there could be play.
side to side, or in and out (thrust).
there is always some play in turbo's.
when the turbo is boosting, it is sucking in the air and therefore it is pulling the wheel/air INWARDS.
when you back off, it goes back to spinning freely.
if you have no bov, the "reverting" air pushes against the turbo's COMPRESSOR wheel to try and escape.
this push of air, thrusts the compressor wheel OUTWARDS.
Long duration of this or high boost and this constant push pull on the compressor can wear it out and eventually cause the compressor wheel to touch the housing due to how much shaft play it has.
and as you can guess, a turbo spinning at 100,000rpm + reversion + time = 100,000rpm spinning wheel hitting static compressor housing... could cause chip, could cause complete failure.
one of the STI's stock turbo (VF22) is very well known for not liking to be fluttered.
no..
all of the above "COULD" happen.
different turbo's have different tollerances.
they are not all built to the same specs (VF22 example).
Point was that a damage that MIGHT happen by no bov/flutter would only be to the compressor wheel.
it will not be the cause of broken exhaust wheel.
ceramic exhaust wheel breakage is always due to a combo of heat and turbine shaft speed.
these 2 cause the epoxy that holds the exhaust wheel to the shaft to delaminate let go.
that's why as a general rule, people say not to boost stock skyline turbo's past 12psi.
as any more than that on a stock turbo (example rb25 with stock turbo), and the heat generate is alot more, and so is the speed at which the turbo has to spin to create the set power/boost.
I say stop trying to spin my words and take in the point that flutter will NOT DAMAGE THE EXHAUST WHEEL as you have said.
your saying they're connected together, over time it can cause it to have shaft play, etc etc
so what does that mean? the front one shits itself and the rear one stays intact?
i'm saying that they both can be damaged because i've had it happen to me, i had no exhaust wheel nor a comp wheel left
and i'm not spinning your words, your just contradicting yourself in what your saying... theres a difference
Yes, if one breaks the other CAN still stay on.
and yes, they CAN both break off.
how can you say that the flutter was the cause of the breakage on your turbo?
you can't.
One of my previous cars was a an ex-rally tx3.
no bov.
15psi
30,000kms on the same turbo without a breakage.
no..
This happened to my friend;
14psi + standard rb20 turbo + flutter + couple of drags
I kept the ceramic bits and are sitting next to my PC :P
nothing happens.
you can plumback.
I don't get what you mean.
you will need a plumback bov, a return hose, and modify your intake between AFM and turbo to be able to plumb the bov return line in to.
Or just buy a skyline intake pipe which already has the return line on it.
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
