Ok, so my stag is FINALLY going on the dyno tomorrow for a tune. What's the guess of RwKW (getting done at UAS in Sydney who only have a 2WD dyno) ??
1997 RS Four V
Mods are:
BOS 3" split dump pipe
Catco Metal Cat
Trust Power Extreme 2 cat back zorst
K&N Panel filter
R34 Intercooler
GTR Fuel Pump
AFC Neo computer
SITC computer
Turbotech mechanical boost controller (expect set to 10psi)
Full service has been done with new filters for everthing, spark plugs, timing belt and water pump so running sweet as a nut.
The prize will be bragging rights for knowing your stagea power figures :D:)
Stu
https://www.sau.com.au/forums/topic/181590-kw-bingo-guess-the-power-output/
I am running 4wd, but Unique Auto Sports only have a 2wd Dyno so they will drop the driveshaft out. I am hoping for 150awkw, so would have to be 160 or so rwkw I guess.
Will be a big improvment over how it is now though, which is the main thing :)
What time are you going there, Stu? I live just around the corner from UAS and have also just booked my car in for some work there (for early next week), so I might come along, meet you and see how your car runs...
you can just undo 4 bolts and drop the front driveshaft, but you will lose about 10kw.
Less power transferred, is less power lost.
You will not loose power going to RWD, you would expect to gain a minor minor amount, being its not fulltime 4WD.
i think the SITC will make it hard to crack 200rwkw with less load points but who knows maybe we can go around and drop the temp probe in to a nice hot cuppa and crack 220rwkw.
EGA4IT made just over 200rwkw with an RS4S and powerfc with similar mods on the same dyno as a comparison.
OK, the results are in and the winner is .....
Tangles :(
Max power 152.9Kw at the rears running just under 10psi. This is a Series 1, not neo motor by the way. And an auto :P
I will scan the printout at some stage but Andrew at UAS did a nice job on the tune. Power deliver is smooth all the way through with no dips and boost holds constant the whole way. Go the $30 Turbotech controller :) A/Fs are around 12 or just under too so nice and safe.
They did not tune the SITC this time as worried about detonation with the side-mount intercooler and I am driving to Brisbane this weekend so I think they are playing it safe. With a FMIC, exhaust cam gear and some more tweaking on the afc and sitc I would hope to see another 20Kw. All in all pretty close to what I was expecting so can't complain about that.
Goldzilla ... sorry I missed your post as my PC at home is dead and I went down there first thing this morning. Is yours the green one coming in for a 'trial fitting' next week ?? :O
Speaking of fitting, the Power Extreme cat back zorst needed a fair bit of manipulation to line up unfortunately. I guess that is the price of mixing and matching local dump pipe and cat with jap exhaust. A word or warning for others I guess, the BOS dump and Catco cat may not line up exactly like factory
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
