My Toyo RA1 are shot. Now with over 250rwkw i am braking traction in 2nd gear under boost.
What tyres do you run and does it hold traction in 2nd gear with over 250rwkw? Can normal street tyres do it or do i need to run semi slicks again?? Over $400 a pop, they arent cheap. I heard Nankung's arent bad in the dry, but will they hold the skyline down?
rofl nankangs... they about $130 a pop for a 17" 225 which is cheap
i have them all round on my car and the rears break traction coming onto boost in 1st and JUST hold on in second
im running standard turbo too, dyno'd at just over 200rwkw so unless you got some 265s on there i dont think theyll hold
mate toyo t1r's are great but pricey....i have hankook k104 sports which arnt too expenseive and they hold pretty good....holds 2nd hitting boost...but not first....thats with 205kw
haha yeah i had 255/50/16s on my old GTR rims :) 16x8, worked quite well actually :( i was surprised
Bridgestone Potenza GIIIs are good too, although wear out quite fast
Toyo Proxies are alright as well, just depending on your budget, go for eitehr or those 3
My R32 has almost 250rwkw and I use Federal 595,s which are great for traction, but its torque thats the real problem, if you have heaps of torque then you will spin tyres pretty easily no matter what you use.
You could keep using UHP street tyres but you will probably find that you will get the same result from most of them, if you use semi slicks you will get more traction but semi slicks wont really reach max grip levels on the street as they wont heat up enough.
You could use something along the lines of the Federal 595RS which is more of a street semi slick (not R compound) with a very soft compound and lots of rubber on the road, check them out at www.federaltyres.com.au.
Yeah heard about those Federal's RS, they seem around the $400 mark as well. I'll shop around.
Yeah torque is the problem. Running high boost, she comes on pretty hard in the middle and thats where the problem is
Im running 255/40/17, i dont think a slight size increase will hold it down
He had 265 17x9
He now has 295 30 R20 20x10
More to do with the better quality rubber overall, but still fat.
1JZ GTE VVTI on 1.1bar, manual has a shit tin of torque due to VVTI, so it does have issues, hence the wider rubber.
look at your alignment (static and dynamic), RA-1's should hold that sort of power when hot. Have you looked at changing cradle angle to inprove traction? we just fitted Super pineapples to the drift car and have found a BIG gain in traction over the std ones.
we run 3mm total toe in
.2-1deg neg depending on track
adjust traction arms to suit ride height (these reduse toe change during suspensiontravel)
Cradle angle increased by about 20mm (front down)
Yeah the RA1's definately hold it down in 2nd gear but they are well and truely past their use by date. Looking for some cheaper replacements but looks like i will have to use R series tyres.
Hey Robo how's it going. Im running the Nankang nsII's on the back in a 255 on 18's. That's the widest i could go due to the offset of the rims. They are not to bad on very grippy roads but generally do break traction in second with 260kw. So i think you might be dissapointed with these tyres. Hope this help's. :cheers:
  • 1 month later...
NO TRACTION!! u got a 1.88 second 60ft time!! r u just f@*kin round or wot??
Read the post, my tyres are shot!!! :whistling:
Anyway ended up getting to Falken Azenis RT615. There still new and a little bit skatey, might test them out this weekend
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
