Hi, all,
I have just had a Power Fc installed on my R34 GTR (still getting used to that phrase - "my R34 GTR" .........). I had also fitted a Nismo R-Tune intake duct, which was promoted as a good thing in various places. The guys at the workshop were dubious about its likely performance, because the flow area at the mouth is really quite restricted. My understanding is that the idea of it is to introduce some level of ram effect into the airbox. (I had also put a Midori panel filter in the box, which was supposed to give enhanced flow over standard - I could not get a Nismo Sports Element.)
When it was being tuned on the dyno, the guys reports that from about 5,500 rpm the intake started whistling, it was so restricted. The power curve also flattened off. This was also influenced by the boost declining from an initial 18 psi or so to about 13 psi. (This is temporarily controlled by a bleed valve, with an EBC going in next week - hopefully.) The suggestion from the workshop is that the intake is responsible for much of the flattening of the power curve (I will post up the dyno graph tomorrow).
I am now considering installing an APEXi Power Intake pod system instead. I am swayed by the argument that the ram effect would be marginal compared to the available flow area - which the pod system will win hands down. Naturally, tuning on a dyno, there will be no ram effect, because the car is not moving. So it is difficult to tell conclusively.
My doubts on all this stem from the fact that Nismo know what they are doing and they have had some pretty high output cars running with this intake. Does anyone else have any experience of this or can they offer an explanation of the differences involved? The R-Tune intake duct sits on the standard airbox, which is unmodified. I have the standard intake pipes. I note that the Nismo cars all have the Nismo intake pipes, which offer improved flow - but they are all downstream of the mouth of the intake. So if this presents a restriction, this will dominate the performance of the overall intake system.
I would appreciate any comments.
Cheers. :(
I think you should be looking elsewhere for the cause of the lost boost.
This is a useful thread which will explain much.
http://www.skylinesaustralia.com/forums/in...=181061&hl=
Lastly, having seen the Nismo duct on a 34 I was suprised by how crappy it is. Nonetheless is its cross sectional area is larger than stock it will be plently big enough.
there is a very simple way to find out what's happening. run it up on the dyno with everything hooked up. then remove the box, intake etc just leaving the two AFMs there. now run it up and see if it's any better. if it is, then get the pods, if it's not stick with the box and nismo intake and keep chasing the problem.
If your 34's airbox is truly unmodified then the first thing you should do is remove the blocking plate in the secondary airbox intake (the one from the wheel well). Mine still had this when it came from Japan as well so it's possible yours does too. Opens up the intake and should be the first thing anyone does when they buy one.
It's there to quieten down the intake but easily removed with a bit of elbow grease.
Thanks, Sewid, I'll take a look at it. Thanks to the other guys for their comments too.
Cheers.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
