hey guys here is one of the pics in the tutorial..you can see the blue plug lying there @ the back...just wanna know where it goes. i already have the intake on. see above. any help is muchly appreciated. Hame :D
  • 1 month later...
has anyone actually fit top feed injectors to this manifold..? i did and there leaking. i used standard rb20 seals.. any idea's
i seen collars u can get to put in there ive seen ppl use on sr20's.. cant find em anywhere though
  • 3 weeks later...
Great thread, answered all my questions regarding this install.
Started her up yesterday, idles smooth as silk :laugh:
Can't wait to try her on the road, f**king winter here now...
Dude, looks like you hooked up your coolant bleed valve. Where did all the hoses go?
You block off the coolant bleed. Most of the hoses are covered in this thread have a read from page 1 :laugh:
Sydney Kid said it wasn't a good idea in one of his posts. I'd like to keep as many of the factory bits as possible.
But if I can block it off, it'll be blocked off.
I took a good look where the water hoses for the bleed valve goes, before i took the old plenum off.
Didn't like the idea of not being able to bleed the air out of the cooling system
This way you don't have to block off any pipes. Just remember to mount the bleed valve so its the highest spot on the cooling system.
Edited by WilYawn
Why hasnt this been stickied yet :P
lots of good information, should be a sticky in either this thread or the DIY/Tutorials thread really
Appreciate the guide, will come in handy when it comes time to put mine on
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
