Oh yeah well good luck to him and who ever else is going. This heat is surly going to put some numbers backwards.
Is the 300zx going to meet the drag strip? :D
Yes, but its stock so Im not exspecting much more than a low 14, ive heard of theme doing 13.4 from Factory, but thats the 2 seater and I bought a 4 seater, ways 1630 without me, HEAVY BITCH ;)
So you like a plump girl with curves hey!!!!
also guys, there's a new cop in town with a grey 300zx (possibly 350z, not sure), names Lucas.
Seems ok,,,,,,,,,, was asking about meets & cruises and people to do burnouts with..
met him at BP the other night. anyone know him??
And who can make a cruise out to Jim's place or somethin on Saturday 27th, even sunday??
NO, not till 4th or 5th, Ill have my car and so will camelo!!!
Is this copper a highway nazi? Be a bit wierd to tell him that shit considering they pick on us cause we have nice cars..
What ride has mello picked up? Or did he get his VL running with turbo gear as he was saying awhile ago?
Edited by Rexlr8
Camelos has got himself A 1988 Nissan Skyline Silouhette, White with White wheels, RB30DET, 210KW ATW.
you might recoginise it, dennis use to own it from the wreckers, mello paid $3000 for it, and its clean as :(
OMFG ROFL, poor bloke, he must be spitting, spent all that money and prob wouldnt have been much slower ten grand ago.
should have bought a nissan :banana:
i feel for him... that sucks, and yeah cruise would be good but id need an exact date so i can make sure im in town for that weekend.
hey jordan when you bought your car how are you going to rego it?
im going to bring mine over unregistered and then just rego it here, rather than f**k around chaning it over agian.
anything special i need to know?
i can just take the papers in and rego it? its roadworthy
itll have to go over the pits or what?
yeah it will have to go over the pits, any change from another state has to.
Get a letter from the previous owner stating their full name and address with rego, vin number, and sale price.
Saying they are selling the car to you, oh and you full details also. and signed with their printed name.
example:
I Fred Smith of 69 Menow Road, NT, 0869, on 23/09/08, owner of Nissan Silvia S13 Rego 123-456, Vin # ?????????????? agree to sell this vehicle to Joe Bloggs of you get the point.
Signed
Fred Smith
{insert squigly signature}
Make sure they have signed all their relevant paperwork.
You'll need at least a few hundred bucks.
Like James said, mines got 12 monthes rego on it and new tyres all round and has just past its inspection
and Ryan, what cars are you looking at? post on here what you get and as for the cruzie!
Saturday 4 of October A run to jims place, thats in 1 and a half weeks or SAT 11 October in 2 and a half weeks jims place, put in your votes NOW :P
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
