Gonna be a major teardown of R32. Next time Oscar, it's not a good idea to laugh when a $15000 bottom end lets go mate, not everything is a joke. Engine failure is serious stuff. Let's just say you've been very fortunate with your car. Looks like nothing to do with tune, just oil supply starvation from launching at 9200 with a stock sump. This bottom end is all going in the bin probably, I'm not just gonna chuck some bearings in and "she'll be right". Fab take note and be very careful what you choose to do to repair your 26.
Just finished discussions with the old man on which path to go down - HKS 2.8, OS 3L or keep a 2.7L capacity. 3L option is too much at $29k, HKS 2.8 is tempting for 800ps stage 2 but too much for stage 3 1200ps option right now, so it'll be a 2.7L capacity again.
On order first thing tomorrow is Trust sump extension, 86.5mm CP pistons/rings, crower rods, R33 GTR crank and R34 GTR block - all brand new from Perth where machining for block and balancing of crank will be done. Trust Dog box is going back in too.
Don't worry, I'll be back stronger than ever.
Edited by BK
How was the oil supply over looked when the engine was built to start with? I don't know much about 26's, although it'd be Russian roulette with nearly 5 times the factory power to happen reliably with the factory sump on any car. Seems like a good opportunity to see if there is anything else that could be improved.
What can I say?
I :whistling: LOVE carnage in my motorsport!!! Speedway is turning me into a sadistic prick.
There is nothing better than pushing a car or engine to its limits and beyond.
http://www.skylinesaustralia.com/forums/Gt...ad-t257137.html
I thought that my RB would be the first in town to go pop considering the 2006 standard rebuild, standard cast pistons, 200+ HARD 1/4 passes with limiter launches, 2 burnout comp wins, wearing my 4 M/T's to the wire and peak holds of boost above 1.7 bar.
The only thing keeping it alive is the N1 oil pump, tomei oil restrictor, sump baffles, oil changes @ <100km and good luck!
On a serious note Ben call me if you want to sell your 16" wheels & M/T's $$$CASH
I reckon these with new bov's and a serious weight reduction I may be able to give the 10's a nudge.
wats up orderd a new r33 gtr crank bearings and rings ill get a new clutch as well were tearing this motor to a bare block clean evry thing make sure it dont happen again and run the bearing in proply so i can burn sum rubber at drags and get sum decent et down the strip its on ozzy wen its back on the road best burnout :):ermm:
You're right Kurt as at 7k rpm and above there is no oil left in the sump on a RB26, it's all in the head.
So $11000 and counting with the new build for the engine. Just got back from the rock, gotta pay for this new bottom end. Xspeed have machined and assembled the brand new 34 block, 33 GTR crank and 86.5mm CP pistons/rings and crower 74mm rods. All brand spankers so I'll have to run in a new engine from scratch. New kings bearings have gone in and most importantly, a TOMEI 1.5mm HEAD RESTRICTOR for the bloody oil issues. Have a Trust sump in the works too, which should cure the 9k + rpm limit. Will be boxed up on Monday so I sould see my brand new bottom end maybe next week. Still gotta pull the engine out still, which is a major mission on a GTR at nearly 400kg with transmission. I can't see this car being done for a couple of months though. HKS turbo is leaking on compressor side so that'll have to get serviced/resealed on the housing.
Oscar I'll see you some time on the weekend OK
Track is becoming a good place to hone your technique on getting the car down the track faster. New manifold is getting ordered this week. Gains from their design is said to be spooling 200-400rpm sooner and 6-15% more power. Can't wait.
Wouldn't you have already had a good manifold to mount a Trust T67 ? Was yours cracked ?
GTR engine and driveline is fully removed from blue car. Finished it about 2hours ago. New bottom end is assembled and sent. Anyone says they can remove an RB26 and transmission from a GTR in 2 - 4 hours as I've heard so much people talk shit about before I'll give em a grand to watch it happen. The GTR must be the worst car in history to work on for rebuilds, give me a RWD car anyday. The engines themselves are great though. I picked up Fabs gearbox to my chest on Friday by myself, try doing that with a GTR box and you'll be walking no more.
Trust manifold that is mounted to now would be a good design and quite nice for a more mild amount of boost. The stainless steel manifolds are quite well known to crack like mine has. So I have ordered a steam pipe manifold from Kyle at 6boost. This will ensure I will not have to replace it again as they come with a lifetime warranty against cracking or defects.
Good work on getting the motor and gearbox out.
Motor is apart totally. Whoever at Jakes performance let this engine go out like this is a bloody dropkick. Rings have bugger all tension (which would explain the engine breathing) and stock nissan main and big end bearings which have copped a hiding. Number 2 conrod bearing let go with number 3 on its way out. Conrod cap 4 and 5 were swapped around and get this, my engine mount bottom nuts were both gone ! Engine was just literally sitting in the car !
Bearing failure was not from oil supply issues at all, as they were not welded to the crank or conrod like Fabs. The car has just been absoluely hammered at a very high rpm for way too long before I bought it. Still going to address oil issues though, cause I ain't doing another rebuild on this car. Not in any hurry to get it back out drag racing, definitely be next year for the R32. I'll race the last night round in the v spec.
^^^^ sucks, but i suppose you gotta expect things like that when its someone else's project first. my car is looking more mismatched than ever....... but i think it has a nice drift pig look to it :D i might have to get out the spray can to match some panels up lol
Nothing a bit of time can't fix cam. You've been pretty patient so far so it should go pretty well.
No racing for me this weekend as my manifold hasn't arrived yet. I'll be out on the 13th if they still run that test and tune, if not then it'll be the following bracket.
I know what it's like to find engine mounts missing bolts BK, I found mine with one missing and the other only hanging on by a couple of threads. Last tome I allow someone else to work on my car. That is the main reason my manifold cracked, the twisting of the motor caused the wastegate pipe to hit the chassis rail while the engine and exhaust was a full temp causing the pipe to crack and split wide open. $1200 later I've got my problem fixed.
http://www.pfes.nt.gov.au/index.cfm?fuseac...y=2009&mo=8
Who is the 26yr old Skyline driver caught hooning last weekend?
Did they have proof or was it just a phone call from the public?
I would like to see the so called 'evidence'.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
